7TPorsh |
7T Porsh ![]() ![]() ![]() ![]() Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California ![]() ![]() |
Running dual webers. Bot a Carter fuel pump, a new line and relocated the pump up front in the spare tire area. Ran new hoses, aluminum line through the tunnel and new filters to the carbs.
When it's hot, maybe over 80 degrees out; the car starts to misfire and buck after I have been driving about an hour. It will start missing then it gets unresponsive to the pedal. Barely idles and then shuts off. I have to sit about 20 minutes to cool off then I can start up and drive for maybe another 5 or 10 then it starts again. Cool weather it runs ok. I did the fuel pump thinking it would fix this. It did get a little better but during these couple weeks of hot weather it stated up again. Hoping this is a simple fix...touching the carbs is a scary task for me to even think about. Don;t want to screw it up worse. I don't have any type of temp gauges at the moment. |
'73-914kid |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California ![]() ![]() |
Oh, one more thing to check for.. do you have the plastic isolators between the intake and the head? This will be something that compounds the problem, as the fuel may be getting cooked by the head temperatures through the intakes. I doubt this is the sole cause, but it definitly may be compounding your issue.
Lo-Fi Version | Time is now: 26th June 2024 - 09:41 AM |
