Engine & Tranny mating, is my tranny dyslexic??? |
stephenaki |
May 23 2012, 08:08 AM
Can I get this one dad?? Group: Members Posts: 1,183 Joined: 11-August 07 From: Palmetto, FL Member No.: 7,987 Region Association: None |
Well, this go around the mating of the tranny and the motor just ain't cooperating. I licked it last time, see page 5 of this thread, but this time it keeps kicking my ass. (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
Anyone got any words of wisdom or tricks of the trade to make this go easier? (IMG:style_emoticons/default/popcorn[1].gif) |
vwlurch |
May 24 2012, 09:47 AM
Newbie Group: Members Posts: 8 Joined: 13-December 10 From: ohio Member No.: 12,483 Region Association: None |
make sure that the clutch is alighned properly with the tool maybe lossen it all up and center it again ?
good luck |
Valy |
May 24 2012, 11:20 AM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
make sure that the clutch is alighned properly with the tool maybe lossen it all up and center it again ? good luck (IMG:style_emoticons/default/agree.gif) Loosen the clutch pressure plate a bit and fit the transmission in place. Take it apart and tighten the clutch plate. Then re-fit the transmission. You may also check that the clutch disk is mounted in the right orientation. You can mount it the other way around and close everything. Ask me how I know... |
slothness |
May 24 2012, 06:20 PM
It's business time Group: Members Posts: 110 Joined: 7-October 04 From: Valencia, CA Member No.: 2,906 Region Association: Southern California |
make sure that the clutch is alighned properly with the tool maybe lossen it all up and center it again ? good luck (IMG:style_emoticons/default/agree.gif) Loosen the clutch pressure plate a bit and fit the transmission in place. Take it apart and tighten the clutch plate. Then re-fit the transmission. You may also check that the clutch disk is mounted in the right orientation. You can mount it the other way around and close everything. Ask me how I know... Yup, I just dealt with the same thing. Make sure the clutch alignment tool slides in and out without resistance. The first time I aligned it, it required a nice tug to come out. The second time I put the disc smack in the center where the tool freely moved without tugging, and wallah, mating season. |
stephenaki |
May 25 2012, 03:58 AM
make sure that the clutch is alighned properly with the tool maybe lossen it all up and center it again ? good luck (IMG:style_emoticons/default/agree.gif) Loosen the clutch pressure plate a bit and fit the transmission in place. Take it apart and tighten the clutch plate. Then re-fit the transmission. You may also check that the clutch disk is mounted in the right orientation. You can mount it the other way around and close everything. Ask me how I know... Yup, I just dealt with the same thing. Make sure the clutch alignment tool slides in and out without resistance. The first time I aligned it, it required a nice tug to come out. The second time I put the disc smack in the center where the tool freely moved without tugging, and wallah, mating season. Sounds like I may have done the same thing as the alignment tool does not slide in easily. Will tackle that first and see what happens, thanks for all the recommendations gents. And Mike, you don't get to comment, you can probably do this shit in your sleep! (IMG:style_emoticons/default/pray.gif) |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:17 PM |
