> 914 Subaru engine cradle?
IanJ
post Apr 9 2012, 05:37 AM
Region Association: Australia and New Zealand
OK...I thought about putting this in the wanted thread (Apologies to the mods if this breaches rules, please delete if inappropriate)
Does anyone know where I can get an engine cradle for converting my 914 using the WRX engine and transmission?
I know you can buy from a few sources and mod to suit but my fabrication skills are lacking and i'd need to pass an engineering check here in Aus.
Any info/leads appreciated.
thenewwazoo
post May 27 2012, 05:27 PM
Just a quick note - if you're planning on building the cradle to bolt directly to the engine (that is, use isolators between the cradle/chassis instead of between the engine/cradle), you're limiting your market to the EJ alone. The stock EZ engine mounts are liquid-filled three-bolt mounts, and are not interchangeable with the EJ's solid 2-bolt mounts.
The stock Subaru subframes, however, accept the same single bolt and locator pin across the EJ and EZ engines, so a cradle built to accept the stock engine mounts will enable either engine type (and presumably the BRZ/FR-S/FT-86's FA20).
IanJ   914 Subaru engine cradle?   Apr 9 2012, 05:37 AM
pktzygt   OK...I thought about putting this in the wanted t...   Apr 9 2012, 07:08 AM
IanJ   Thanks but I believe even the renegade one needs m...   Apr 9 2012, 08:05 AM
76-914   Thanks but I believe even the renegade one needs ...   Apr 9 2012, 08:58 AM
IM101   I am just about to start production on the cradles...   Apr 9 2012, 10:22 AM
pktzygt   I am just about to start production on the cradle...   Apr 9 2012, 02:10 PM
pktzygt   Thanks but I believe even the renegade one needs ...   Apr 9 2012, 02:15 PM
dlo914   [quote name='IanJ' post='1663284' date='Apr 9 201...   Apr 17 2012, 11:50 AM
DBCooper   For our project we used the Small car engine moun...   Apr 18 2012, 07:26 PM
IanJ   DBCooper. Do you have measurements for your cut ou...   Apr 21 2012, 10:54 PM
BIGKAT_83   OK...I thought about putting this in the wanted t...   Apr 9 2012, 10:03 AM
matthepcat   Finally!! Someone is doing this!! ...   Apr 9 2012, 11:44 AM
wingnut86   Competition makes your competitors more focused on...   Apr 9 2012, 01:20 PM
76-914   914World Group-By discount?? :agree: Or group ...   Apr 9 2012, 05:27 PM
ChrisNPDrider   :beer2: :popcorn:   Apr 9 2012, 02:17 PM
effutuo101   Just waiting on delivery... :D   Apr 9 2012, 04:27 PM
Brett W   I have built two bars that bolt in and allow use o...   Apr 9 2012, 09:21 PM
wingnut86   Competition makes your competitors more focused on...   Apr 10 2012, 08:17 AM
matthepcat   Brett, RH makes you buy the whole package and not ...   Apr 10 2012, 09:01 AM
IM101   I will be making an official release thread and a ...   Apr 10 2012, 12:30 PM
ChrisNPDrider   Ian - you should visit Camp914, in your area. :sh...   Apr 10 2012, 01:59 PM
r_towle   Is there a decent shifting solution for a subaru t...   Apr 10 2012, 02:18 PM
IM101   Is there a decent shifting solution for a subaru ...   Apr 10 2012, 02:25 PM
FourBlades   Looks like a nice product. Can you run the stock ...   Apr 10 2012, 02:26 PM
IM101   Yes. For fit/non cutting porposes I recomend that...   Apr 10 2012, 02:36 PM
my928s4   I just bought my Subaru EJ205 Engine and it came w...   Apr 10 2012, 02:38 PM
wingnut86   Being a true southerner, I'm for an A/C soluti...   Apr 10 2012, 05:42 PM
partwerks   Will this cradle allow one to use the stock shift ...   Apr 10 2012, 10:31 PM
IM101   my928s4: The ETA is two weekends from now, at leas...   Apr 10 2012, 11:12 PM
pktzygt   I understand the reasoning for placement of motor ...   Apr 11 2012, 12:00 PM
IM101   I understand the reasoning for placement of motor...   Apr 11 2012, 09:09 PM
jimkelly   i have emails from RH that say the suby trans won...   Apr 17 2012, 06:27 AM
DBCooper   I think you're in for a lot of extra work and ...   Apr 17 2012, 07:49 AM
IM101   i have emails from RH that say the suby trans won...   Apr 17 2012, 11:36 AM
IM101   Here are a couple of shots from my first run to ge...   Apr 17 2012, 11:50 AM
jimkelly   any idea what shipping will cost - west coast to e...   Apr 18 2012, 11:22 AM
IM101   Hey thanks man, for shipping UPS quoted about 75...   Apr 18 2012, 02:12 PM
Jake Raby   Nope.. Return was fine but the hand holding was ...   Apr 22 2012, 08:55 AM
Zaney   Hi, With the cradle in the car, does the axle from...   Apr 24 2012, 12:00 PM
jimkelly   hopefully not as it is my understanding that some ...   Apr 24 2012, 12:58 PM
IM101   Hi, With the cradle in the car, does the axle fro...   Apr 24 2012, 01:21 PM
jimkelly   any concerns with the amount of cantilever or thic...   May 15 2012, 11:18 AM
IM101   any concerns with the amount of cantilever or thi...   May 15 2012, 12:13 PM
falconfp2001   Can't wait to order one and since no one else ...   May 16 2012, 10:16 PM
wingnut86   Is there any way to mock up the trunk cuts or theo...   May 17 2012, 05:40 AM
IM101   falconfp2001; Thank you, I am doing ok with capita...   May 17 2012, 11:22 AM
IM101   :Qarl: Look what just showed up! Super amped t...   May 17 2012, 11:29 AM
drdave427   :Qarl: Look what just showed up! Super amped ...   May 17 2012, 01:06 PM
falconfp2001   [quote name='IM101' post='1677247' date='May 17 2...   May 19 2012, 10:10 AM
falconfp2001   :Qarl: Look what just showed up! Super amped ...   May 17 2012, 04:00 PM
Brett W   BTW, on our conversion cradle you don't have t...   May 17 2012, 12:54 PM
IM101   True, however the 500$ (more for exchange rat...   May 18 2012, 01:46 AM
strawman   Why not use modified 911 axle shafts? Dutchman Axl...   May 18 2012, 11:01 PM
charliew   I've been doing other things but just got back...   May 19 2012, 12:19 AM
BIGKAT_83   The axles will work fine BUT... be careful Subaru ...   May 19 2012, 07:46 AM
Brett W   Bob, drive that car over here so I can see it runn...   May 19 2012, 08:49 AM
BIGKAT_83   Brett it is sweet with the EZ30. I even think it f...   May 19 2012, 10:00 AM
IM101   Strawman: Several reasons I decided not to go in t...   May 19 2012, 11:35 AM
IM101   charliew: I have some good ideas brewing with the...   May 19 2012, 12:18 PM
falconfp2001   charliew: I have some good ideas brewing with th...   May 22 2012, 12:18 PM
IM101   Guys some new info on the axles, i didnt want to c...   May 22 2012, 11:08 AM
IM101   Well technically it will work for any subaru engin...   May 22 2012, 01:02 PM
falconfp2001   Well technically it will work for any subaru engi...   May 22 2012, 01:39 PM
falconfp2001   Well technically it will work for any subaru eng...   May 29 2012, 12:35 PM
thenewwazoo   I'm very interested in this thread - I actuall...   May 26 2012, 09:00 PM
Porcharu   I'm very interested in this thread - I actual...   May 29 2012, 12:53 PM
abnrdo   Very interesting. I may not have to build my own ...   May 26 2012, 10:46 PM
thenewwazoo   Just a quick note - if you're planning on buil...   May 27 2012, 05:27 PM
IM101   Interesting, I’d appreciate a picture of the mou...   May 29 2012, 11:38 AM
Lennies914   Any updates? I just bought my roller yesterday and...   Jul 22 2012, 12:53 PM
badmiata   Awesome thread, you've got about a yr before I...   Jul 22 2012, 02:07 PM
IM101   Im going to try and not jinx myself, but it seems ...   Jul 22 2012, 04:45 PM
falconfp2001   Cool deal. If the cradle is going to run about 500...   Jul 22 2012, 07:57 PM
my928s4   Any progress on the production run?   Aug 6 2012, 02:58 PM
IM101   MAN IM PUMPED! here is the update: http://www...   Aug 6 2012, 08:26 PM
matthepcat   Very Cool! Talk about upsetting the RH crew th...   Aug 7 2012, 01:48 PM
33 User(s) are reading this topic (33 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 28th December 2024 - 06:11 AM
