rwilner |
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States ![]() |
I was told this engine came from a 1.7 that was in a 914. I'm tearing it down to rebuild into a 2056.
First, I found an M12 or M14 triple square bolt with a spring under it. This bolt is located between two pushrod tubes. I'm guessing this is the oil pressure relief since I didn't find the giant slotted plug I was expecting to find...true? Second, there is no windage tray. Did the early motors not have a windage tray? Should I source one and install it? I don't see anyplace in the casting that would receive the tray... Third, I didn't find the serial number where I expected it to be -- in front of the breather tower. Where else could it be? It seems like a low mile case to me...lifters and cam bearings show minimal wear, the cam looks to even be reusable to my untrained eye. If I had to guess i'd say this was a low-mile motor that got parked due to FI problems or something. have no pics but will post some tonight. |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Serial numbers: Early bus cases didn't have a number. It was located on the fan housing. An early bus case can be identified by the oil filler passage next to the taco plate opening, the fuel pump flange being finished for use, and the lack of a dipstick tube on the top of the case.
If you add a windage tray, you'll need the tray, the four seals, and an oil pickup modified to allow attachment of the tray. The Cap'n |
rwilner |
Serial numbers: Early bus cases didn't have a number. It was located on the fan housing. An early bus case can be identified by the oil filler passage next to the taco plate opening, the fuel pump flange being finished for use, and the lack of a dipstick tube on the top of the case. based on this I do indeed have a 914 case, as the dipstick is on top of the case. QUOTE If you add a windage tray, you'll need the tray, the four seals, and an oil pickup modified to allow attachment of the tray. The Cap'n Is there anything special about the cases that came from the factory with the tray installed? In other words -- does the tray slip into some grooves that were cast into the later cases (which may be absent in my early 1.7 case)? |
pilothyer |
Member ![]() ![]() ![]() Group: Members Posts: 838 Joined: 21-May 08 From: N. Alabama Member No.: 9,080 Region Association: South East States ![]() |
Is there anything special about the cases that came from the factory with the tray installed? In other words -- does the tray slip into some grooves that were cast into the later cases (which may be absent in my early 1.7 case)? The early WO cases up untill 1972 didn't come with the oil baffle plate. They didn't even have the special ribs to install one until Engine # WO 074387 in 1971. The objective was to insure that the oil intake pipe remained submerged in oil during sharp cornering. |
rwilner |
They didn't even have the special ribs to install one until Engine # WO 074387 in 1971. I have no idea how you know this but that is a pretty impressive piece of trivia. I'll find the serial number to see if my case has the ribs, and if so, source the baffle and pickup (or drill a hole in my pickup). |
Lo-Fi Version | Time is now: 24th June 2024 - 05:35 AM |
