> need to do a clutch today, can I do it w/out removing the trans?
ottox914
post May 25 2012, 06:27 AM
The glory that once was.
Been a bit since the last time I did a clutch IN a car. I seem to recall hearing of doing one w/out taking the trans out. I'd rather not have to do that, as removing the exhaust, turbo bits, and trans adds a lot more work. Ant thoughts or hints/tips? Its just me in the garage today, so hopefully I can get this done for the weekend.
Cupomeat
post May 29 2012, 02:55 PM
missing my NY 914 in VA
THat is VERY unusual.
Perhaps one side of the diaphragm has cracked/broken causing the uneven pressure across the wear surface.
I've never seen one like that, but it has to fail somehow.
As for the 1/4" deeper hub on the disk. Not sure it should matter but I don't know which is original length, the current (and the other is 1/4" shorter) or the other way around.
Get a measurement and we could tell you which is stock length.
Eitherway, mostly likely you'd be fine as there is a fair amount of room in there. You just wouldn't want the splines ending and the disk being pushed backward by the input shaft toward the pressure plate.
Interesting failure, thanks for sharing.
ottox914   need to do a clutch today   May 25 2012, 06:27 AM
r_towle   nope, it needs to come out. rich   May 25 2012, 06:38 AM
URY914   You could leave the trany in but it would be the f...   May 25 2012, 06:40 AM
Dr Evil   Wow, it would be the first time I have heard of it...   May 25 2012, 06:41 AM
Dr Evil   Actually, ya you can leave the tranny in, but you ...   May 25 2012, 06:41 AM
r_towle   I suppose if you have some training in magic it mi...   May 25 2012, 06:43 AM
bembry   If you still have the underbody heat shield in p...   Jun 4 2012, 04:32 PM
Luke M   Every clutch job that I've done in a 914 I had...   May 25 2012, 06:44 AM
Cap'n Krusty   It CAN be done without removing the tranny from th...   May 25 2012, 08:08 AM
dakotaewing   Wouldn't it be faster to drop the entire drive...   May 25 2012, 08:54 AM
rjames   Please don't let anything rest on the heat e...   May 25 2012, 10:24 AM
pt_700   although it's been awhile for me too, i agree ...   May 25 2012, 10:33 AM
ottox914   I've had an engine and trans out more times th...   May 25 2012, 03:12 PM
Dr Evil   Dave, reply sent. Lets do this! :evilgrin:   May 25 2012, 03:44 PM
ottox914   Just gave in and pulled the trans after taking som...   May 29 2012, 02:47 PM
Cupomeat   THat is VERY unusual. Perhaps one side of the dia...   May 29 2012, 02:55 PM
Dr Evil   Any of those disks should be fine. The 4 spring di...   May 29 2012, 03:00 PM
Valy   How is your flywheel? Looks like the throwout bear...   May 29 2012, 05:27 PM
ottox914   Hows THIS for customer service... On Jun 4, 2012...   Jun 4 2012, 08:46 AM
ape914   Been a bit since the last time I did a clutch IN ...   Jun 4 2012, 11:57 AM
ottox914   Been a bit since the last time I did a clutch IN...   Jun 4 2012, 05:07 PM
- Lo-Fi Version Time is now: 26th November 2024 - 04:20 AM
