I finally split my 1.7 case, pics added |
rwilner |
May 29 2012, 08:49 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I was told this engine came from a 1.7 that was in a 914. I'm tearing it down to rebuild into a 2056.
First, I found an M12 or M14 triple square bolt with a spring under it. This bolt is located between two pushrod tubes. I'm guessing this is the oil pressure relief since I didn't find the giant slotted plug I was expecting to find...true? Second, there is no windage tray. Did the early motors not have a windage tray? Should I source one and install it? I don't see anyplace in the casting that would receive the tray... Third, I didn't find the serial number where I expected it to be -- in front of the breather tower. Where else could it be? It seems like a low mile case to me...lifters and cam bearings show minimal wear, the cam looks to even be reusable to my untrained eye. If I had to guess i'd say this was a low-mile motor that got parked due to FI problems or something. have no pics but will post some tonight. |
Harpo |
May 29 2012, 06:54 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
You mentioned that you will be using ARP fasteners. Will you be using the head studs and the through bolts.
Thanks David |
rwilner |
May 29 2012, 07:31 PM
You mentioned that you will be using ARP fasteners. Will you be using the head studs and the through bolts. Thanks David From what I've read...(this is my first build) The Arp head studs and through bolts are only an advantage if youre going to nickies. Some things I read indicate that the arp head studs and through bolts have some compatibility issues with stock cylinders due to expansion characteristics, but who knows... I will be using the arp fasteners on reconditioned stock 2.0 rods and stock head studs and through bolts. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:39 PM |
