Non-NOS Interior Light is a piece of @#$%, Of course, you already knew that! |
JawjaPorsche |
May 31 2012, 02:21 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I had my back pad recovered so I replaced my broken original interior light. At least, I thought I replaced it. Could not find NOS so I got the VW Empi light. Not even close to being original! I had to "jury-rig" the light to make it stay in the pad. I will not be using it because I am afraid to touch it because it may come out of the pad! I don't drive at night anyway! Looks good from a distance! (IMG:style_emoticons/default/beerchug.gif)
Attached thumbnail(s) |
Tom_T |
Jun 1 2012, 12:44 PM
TMI.... Group: Members Posts: 8,320 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
I don't know if this is the same one with a white button, but I noticed it on evil-bay recently as a possible substitute with a white button which you could paint "chrome" into the bezel edge backside. Can't speak to it's fit, quality, etc.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...=true&rt=nc That link now shows ended, but contact the vendor DSNW who carries them. Also be sure o use proper wattage bulds per the 914 owners manual, because there were brighter higher wattage dome light bulbs out there which fit in 914s, but were intended for other VWs & other cars whose dome light mounting point could stand more heat. This is a common problem on interior & exterior lights where folks try to bump the light output/brightness with a higher wattage bulb - or save coin by using an off-brand cheaper correct wattage bulb which may or may not have been made to the factory specs for heat output - and then they end up with a more expensive fix due to a fried lens! (IMG:style_emoticons/default/dry.gif) "Back in the day" I had the wrong one in my 914 dome light, which melted/warped the lens & burnt through a bit in the center of my now "unobtanium" original light! (IMG:style_emoticons/default/mad.gif) Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 21st September 2024 - 06:48 PM |
