clutch pivot shims |
mightyohm |
May 26 2004, 06:44 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
How do you determine the shim thickness for the clutch pivot?
Say I do not know if the pivot was adjusted correctly before (the fork was rubbing on the pressure plate) and I just had the flywheel resurfaced. How do I know if it's adjusted correctly now? What is the thickness of the stock shim supposed to be? Can I measure the flywheel in some way and come up with a number for the addtional shim amount? |
mightyohm |
May 28 2004, 01:49 AM
How much free play should there be?
Thanks! |
Lo-Fi Version | Time is now: 26th June 2024 - 01:40 AM |
