JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
Okay so as you saw in the other thread I just bought 2000 z28 with an LS1 in it. I got a great deal on it & just bought the whole car. Since it is a driving car I am going ot get everything else ready to go before I pull it. Question is what things should I consider doing to my car? I allready have a 5-lug converison done with 944 turbo Brembo's up front.
My chassis is solid but should I consider adding a cage? Is it needed? What transmission should I use? I know the 901 can handle it with 1st bypassed. I'd really like to do a Boxters S 6 speed transmission. If I have to spend money getting an adapter plate. Why not upgrade my tranny also? For an engine mount did anyone make a cradle? Or did you just do a bar setup like stock but setup for the LS1 motor mounts? I'd like to keep the a/c. What would I need to make that work in my 914? While everyone is welcome to put there 2cents in. I'd really like to hear from all the guys who have done the LS1 conversion. Do you run the stock water pump or something else? I added a pic of my car as it currently sits. I will be painting it also (or Jerry Mahoney will) at some point. Leaning towards Phoenix red Attached thumbnail(s) ![]() |
pdlightning |
Member ![]() ![]() Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California ![]() |
There are a few LS conversions, 901, 915 and 930 trans have been used. If you are an engineer, you could use anything you want including an Audi 6 speed.
I am doing the LS1-915-3:10-1 r/p w/ 930 cvs. Start a thread so specifics can be commented on and the great people here will do there best to assist you. There are a lot of issues on the build that are already commented on here. Do a search on each issue and you will see the value of experience on this forum. But please share your build with us as we all learn from each other! Good luck! |
Lo-Fi Version | Time is now: 27th June 2024 - 08:40 AM |
