clutch pivot shims |
mightyohm |
May 26 2004, 06:44 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
How do you determine the shim thickness for the clutch pivot?
Say I do not know if the pivot was adjusted correctly before (the fork was rubbing on the pressure plate) and I just had the flywheel resurfaced. How do I know if it's adjusted correctly now? What is the thickness of the stock shim supposed to be? Can I measure the flywheel in some way and come up with a number for the addtional shim amount? |
ChrisFoley |
May 28 2004, 07:38 AM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I couldn't find a spec on it, but basically you want the fork to have sufficient travel to fully disengage the clutch when the pedal is depressed.
That means the fork should be towards the front of the opening in the side of the bellhousing when the engine and gearbox are together. You just don't want it so far forward that there is any interference. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:30 AM |
