rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,116 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
the only markings on it are Atz and 17 on the outside half with VW and 22 on the inside half. it has a banjo fitting on for the brake line connection.
k Attached image(s) ![]() ![]() |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
That's an early 914 front caliper. Basically made off the same casting as the 911 rear calipers with the fluid inlet on the back and not the side and, with a 42mm piston vs the 38mm variety on the 911.
These have standard hex head M7 fasteners vs. the Rive versions on the 911 caliper. They will only work with the early 914 rotor offset. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 01:08 PM |
