mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
How do you determine the shim thickness for the clutch pivot?
Say I do not know if the pivot was adjusted correctly before (the fork was rubbing on the pressure plate) and I just had the flywheel resurfaced. How do I know if it's adjusted correctly now? What is the thickness of the stock shim supposed to be? Can I measure the flywheel in some way and come up with a number for the addtional shim amount? |
JFJ914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States ![]() ![]() ![]() |
The shim shown in the PET is just a washer. Two are about all you can use and still have enough thread on the pivot to secure it.
Lo-Fi Version | Time is now: 26th June 2024 - 01:48 AM |
