corpselaurel |
Member ![]() ![]() Group: Members Posts: 90 Joined: 15-April 04 From: usa Member No.: 1,931 ![]() |
I am trying to figure out what to do about my suspension. I want dampening adjustability and height adjustability. I am not very familiar with products for the 914. If it was any other car I would go with something like Tein SS or H&R etc.
What coil overs do you guys use? Any full coil over setups available? (Threaded shocks not sleeves) Should I go with a koni shock threaded sleeve setup? I have a budget of about $800 give or take. I would like to get a new torsion bar too. Does it make any difference if I am doing a 5 lug conversion from a 911 in the front? Where did you get what you're using? |
fiid |
Turbo Megasquirted Subaru Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California ![]() |
How far is your bottom spring clip groove from the bottom of the shock (far end of the ring that get's bolted to the trailing arm??
How far is there between the grooves? The perches have quite a range of adjustability, so I'd be suprised if it couldn't be made to work. I'll go measure mine when I can find the tape measure :-) Fiid. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:29 AM |
