corpselaurel |
Member ![]() ![]() Group: Members Posts: 90 Joined: 15-April 04 From: usa Member No.: 1,931 ![]() |
I am trying to figure out what to do about my suspension. I want dampening adjustability and height adjustability. I am not very familiar with products for the 914. If it was any other car I would go with something like Tein SS or H&R etc.
What coil overs do you guys use? Any full coil over setups available? (Threaded shocks not sleeves) Should I go with a koni shock threaded sleeve setup? I have a budget of about $800 give or take. I would like to get a new torsion bar too. Does it make any difference if I am doing a 5 lug conversion from a 911 in the front? Where did you get what you're using? |
1973914 |
Member ![]() ![]() Group: Members Posts: 353 Joined: 16-May 03 From: Washington, DC Member No.: 703 ![]() |
I am adjusted as low as they will allow at the moment, thus the need to change to the threaded perches. Thanks for doing some research on the measurements, thats great! Think that to really get the full range the threaded set up is the way to go.
Talked to the Ground Control guys, they said it wont work on the 82k1722 koni reds. Something about them being to wide to fit the collar. So.... will have to see what part number i have! |
Lo-Fi Version | Time is now: 29th June 2024 - 02:25 AM |
