Butterfly valves are rusted shut, any suggestions on getting them to move?, Solex 40 Pii-4's |
Steve73 |
Jun 6 2012, 11:28 PM
Photographer/Shade Tree Mechanic Group: Members Posts: 125 Joined: 2-July 11 From: Nashville Member No.: 13,269 Region Association: South East States |
Hi,
I have a new car that I'm working on that hasn't been run in at least 3 years (maybe not since '86) It's in pretty good shape but one of the carbs had water enter into the throttle body and sit on top of the carb causing rust. Now it is rock solid and won't move. (IMG:style_emoticons/default/hissyfit.gif) What should I use to brake up the rust? something like CLR? Not many cars in here using the 40 Pii-4's, why is that? I have searched on here for info on them without comming up with much. Most of my info has been comming from 356 sites. |
euro911 |
Jun 7 2012, 12:43 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,860 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
A lot of folks say Solexes are finicky, but if dialed-in correctly, are great carbs. That's what I've always used on 356/912 motors.
I have a set of Weber IDFs in the same condition as yours (possibly worse). I've tried WD-40, PB blaster, carb cleaner and a U/S tank, all with negative results. Diesel fuel has been suggested as a good penetrating fluid, but I'm going to try some Berryman's carb dip next, since I already have a big can of it around here somewhere. |
Mark Henry |
Jun 7 2012, 05:44 AM
Lo-Fi Version | Time is now: 4th January 2025 - 04:51 PM |
