Will these Fuchs copies fit my 914 with AA GT flares?, 7x17 on 1" adapters with 5X130MM BOLT PATTERN |
Rbcm2005 |
Jun 7 2012, 02:34 PM
Newbie Group: Members Posts: 49 Joined: 14-January 12 From: Nor. Cal. Member No.: 14,003 Region Association: Northern California |
I give up on looking for real Fuchs with the RSR finish that are in decent shape and at all affordable.
Found these on a tip from another thread: http://www2.cip1.com/ProductDetails.asp?Pr...Code=C32-FU172B 7 x 17. I will be installing them on AA's 5 lug adapters which means that they will be sticking out an additional 1 inch. Is the 5x130mm bolt pattern what I want - or the 5 x 112? Thanks as always for all the help here. (IMG:style_emoticons/default/party.gif) |
brant |
Jun 7 2012, 02:39 PM
914 Wizard Group: Members Posts: 11,642 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I give up on looking for real Fuchs with the RSR finish that are in decent shape and at all affordable. Found these on a tip from another thread: http://www2.cip1.com/ProductDetails.asp?Pr...Code=C32-FU172B 7 x 17. I will be installing them on AA's 5 lug adapters which means that they will be sticking out an additional 1 inch. Is the 5x130mm bolt pattern what I want - or the 5 x 112? Thanks as always for all the help here. (IMG:style_emoticons/default/party.gif) those look like the type of copies with the square cut pedals. not a good look in person you can have real fuchs refinished in and RSR finish I guess it depends if you 1) really have to have 17's 2) mind having that square cut pedal that looks a lot like a fake |
Lo-Fi Version | Time is now: 20th June 2024 - 11:49 PM |
