ruby914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None ![]() |
I will start body work on my hoods soon and wonder what is the best way to address this issue.
The sub structure to hood panel bonds, on both of my cars front hoods, have visibly degraded. Rear hoods are not bad. The one shown has a lot of flex and has lost 80% of the bond. There are some small dents I need to work out then I figure I should rebond the sub structure before final prep for paint. I am thinking, let it cure with a good rubber seal and the hood shut to take any rack out. Too rigid a bond and I would be concerned about a mark off on the top, to soft and it will flex and not hold up... Any suggestions on bonding agent or proven method? Attached image(s) ![]() |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
The sub structure to hood panel bond on both of my cars front hoods have visibly degraded. Each and every hood i have ever seen had the exact same problem ... (IMG:style_emoticons/default/dry.gif) |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
The sub structure to hood panel bond on both of my cars front hoods have visibly degraded. Each and every hood i have ever seen had the exact same problem ... (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 09:04 PM |
