ruby914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None ![]() |
I will start body work on my hoods soon and wonder what is the best way to address this issue.
The sub structure to hood panel bonds, on both of my cars front hoods, have visibly degraded. Rear hoods are not bad. The one shown has a lot of flex and has lost 80% of the bond. There are some small dents I need to work out then I figure I should rebond the sub structure before final prep for paint. I am thinking, let it cure with a good rubber seal and the hood shut to take any rack out. Too rigid a bond and I would be concerned about a mark off on the top, to soft and it will flex and not hold up... Any suggestions on bonding agent or proven method? Attached image(s) ![]() |
Jeff Hail |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 ![]() |
Wurth its weight in gold. It won't suck the outer skin down as it cures leaving low spots. When the Miata's came out they had a bond issue on the aluminum hoods and this is what the factory recommended. Thats how I found this.
Lo-Fi Version | Time is now: 25th June 2024 - 08:37 PM |
