> 914-6 tail-shifter rear shift rod end - trouble?, Shouldn't this come apart somehow?
smj
post Jun 9 2012, 06:20 PM
"Dude, Steve from Berkeley."
I got my tail-shifter shift linkage bushings from Pelican on Friday; today I happily jacked up my 914-6 to try to put them in. I knew there were differences between the linkage for the -6 and the -4, but I'm not clear how much of what I'm seeing is factory and how much is Mickey...
I did start off following this thread: http://www.914world.com/bbs2/index.php?showtopic=109708 But things diverged pretty quickly. For example, there's a U joint at the firewall end instead of the pair of pivots:
Well maybe that's the way it should be. Looks like somebody replaced the one nut not too long ago... Moving on, here's the sad state of affairs at the far end after I unbolted the support bracket:
Bushing is toast, of course - looks to be rubber, not plastic. The firewall end of the rear shift rod has flanges for the U joint. Wait a minute... How the heck do I get the bracket off?!? I looked for a set screw at the back end of the rear shift rod, but it looks like a rivet:
What the... I poked around at what I think should be a set screw, but it isn't hex shaped inside - and I can pass a 2mm Allen wrench all the way through, it's completely hollow. Here's the best I can do for a close up of both sides:
So... Is this some Mickey Mouse "improvement" somebody's made along the way, or is there a trick to getting that end/bracket off of the rear shift rod? The clear sign of welding about six inches in from the end does not comfort me any...
Thanks! I'm gonna go get some coffee and pray somebody's got a tip for me while I work at the shifter end of things...
sixnotfour
post Jun 9 2012, 07:06 PM
Nope Totally -6 linkage someone has welded a different tube , but not unusual to clear different -6 cases.
-6 linkage is nothing like -4 linkage.
remember your a SIX owner
smj
post Jun 9 2012, 10:13 PM
QUOTE(sixnotfour @ Jun 9 2012, 05:06 PM) *
Followed by:
QUOTE(sixnotfour @ Jun 9 2012, 07:09 PM)
That being said, you're rear bracket is not going to accept a stock bushing, see pics,
Okay, so the U joint and most of the rear shift rod is a replacement? So for a stock -6, you can take the bracket off the firewall-end, get some kind of bushing on it, and replace?
The cut bushing does not want to go in there. Tried trimming the shorter lip down, all I did was make a blood offering to the gods back in Zuffenhausen. Cutting out a 1/4" section didn't help appreciably, and at some point if I cut a large enough section it'll just come off while driving. But, maybe one more try...
Not sure if I should bother with the firewall busing at this point - it's dark, and the coupler just inside the firewall is being difficult.
I had quite a fight with the shifter-end bracket bushing, but at least I got that end back together. Here's hoping it works when I let the car down...
- Lo-Fi Version Time is now: 26th November 2024 - 01:22 AM
