> Micro1000 CHT Gauge, my preferred setup
McMark
post Jun 13 2012, 10:44 AM
914 Freak!
I was asked about which CHT gauge to get and thought that I had posted this info about the Micro1000 over here some time ago. Apparently not. (IMG:style_emoticons/default/rolleyes.gif) So here's my preferred CHT setup because it has an original looking appearance, it's temperature compenstated, and the sensor and wiring is QUALITY stuff. The temperature compensation is important because the crappy VDO setup (and other cheapies) will read 1° off for every 1° above or below 70° inside your car. The VDO wiring can also lead to erroneous readings due to how the thermocouple works and what are called 'cold-junctions'.
CHT Gauge
This is the Micro 1000 gauge as mentioned. It ranges from 0-600 degree F or 0-300 degrees C. The top row of numbers is F, the bottom row is C. It's got two thumbscrews on the back for the collar that will hold the gauge in the dash (or wherever). It comes with a bulb assembly included for night visibility (I forgot to take a picture of that). The back has a + and a - connection for the wire extension. You want the 2" version.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.paintandmetal.com-419-1339605841.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.paintandmetal.com-419-1339605842.2.jpg)
Sender
You will need to buy the appropriate probe/sender for your application. A standard Type IV spark plug is 14 mm. The smaller plugs that Len is using is a 12 mm motorcycle spark plug. I can't vouch for which sender should be used for this application. The sender only comes with about 12" of wire. You will need to purchase an extension lead (see below). The sender comes with a section of heat shrink tubing to protect the screw connections between the sender and the extension leads. The section of wire close to the heat source is protected by a braided wire exterior. This is a very nice feature. (IMG:style_emoticons/default/biggrin.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.paintandmetal.com-419-1339605843.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.paintandmetal.com-419-1339605843.4.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.paintandmetal.com-419-1339605844.5.jpg)
Extension Leads
You will need to purchase either the 7' or the 15' CHT extension lead (make sure you don't accidentally get the EGT leads). These are special wires. You can not use normal copper wire to extend the wires. The wires come pre-crimped with the appropriate connections. So it's a simple plug in installation. I purchased the 15' kit for my 914 as I suspect the 7' is too short, unless you're doing something unique.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.paintandmetal.com-419-1339605844.6.jpg)
This is the link to buy the whole setup.
And part numbers:
Guage: 10-01425
Sender: 10-00823
Extension: 10-01443
Valy
post Jun 13 2012, 01:39 PM
So is the gauge smaller than other 52mnemonic gauges?
rwilner
post Jun 13 2012, 01:56 PM
No Ghosts in the Machine
QUOTE(Valy @ Jun 13 2012, 03:39 PM) *
It's a standard 52mm gauge. If you're replacing your clock in a stock center console, you'll need to get creative to fit it into the 60mm hole. I used black gorilla tape. I think Rich Towle found a piece of PVC pipe at home depot that had the perfect ID and OD.
McMark   Micro1000 CHT Gauge   Jun 13 2012, 10:44 AM
biosurfer1   despite being sick, you are not crazy :D ...you di...   Jun 13 2012, 11:11 AM
Mark Henry   Cool...er... hot :D I don't see the sender f...   Jun 13 2012, 11:30 AM
ConeDodger   This is the one you used on my car...   Jun 13 2012, 11:35 AM
Steve Pratel   This is the one you used on my car... How do y...   Jan 6 2015, 07:11 AM
Elliot Cannon   My biggest problem with the VDO is the lousy conne...   Jun 13 2012, 11:50 AM
McMark   No, there is no 12mm sender. But you can use the...   Jun 13 2012, 12:03 PM
Mark Henry   No, there is no 12mm sender. But you can use th...   Jun 13 2012, 12:48 PM
Steve Pratel   No, there is no 12mm sender. But you can use th...   Jan 6 2015, 07:09 AM
yeahmag   I have used the same one for years now and love it...   Jun 13 2012, 12:11 PM
Jeffs9146   Here you go!   Jun 13 2012, 12:54 PM
rwilner   Here's mine (pardon the crappy iphone pic). T...   Jun 13 2012, 01:25 PM
gothspeed   Here's mine (pardon the crappy iphone pic). ...   Sep 14 2012, 02:33 PM
Valy   So is the gauge smaller than other 52mnemonic gaug...   Jun 13 2012, 01:39 PM
rwilner   So is the gauge smaller than other 52mnemonic gau...   Jun 13 2012, 01:56 PM
McMark   This totally jogged my memory. Westach is about ...   Jun 13 2012, 01:54 PM
McMark   Yup, you can get black PVC and make an adapter tha...   Jun 13 2012, 02:17 PM
jim_hoyland   Just installed a Micro 1000 CHT. Works fine but ca...   Sep 13 2012, 04:33 PM
76-914   Just installed a Micro 1000 CHT. Works fine but c...   Sep 13 2012, 05:58 PM
jim_hoyland   Just installed a Micro 1000 CHT. Works fine but ...   Sep 13 2012, 08:39 PM
McMark   [quote name='76-914' post='1738805' date='Se...   Sep 16 2012, 11:44 AM
jim_hoyland   There's a plastic diffuser in front of the b...   Sep 16 2012, 04:19 PM
worn   I was asked about which CHT gauge to get and thou...   Sep 14 2012, 01:38 PM
ConeDodger   I was asked about which CHT gauge to get and tho...   Sep 14 2012, 02:27 PM
FourBlades   Just to add a little update. I ordered one of the...   Mar 1 2013, 10:04 AM
michael7810   I'm very happy with the Micro 1000 dual needle...   Mar 1 2013, 05:11 PM
FourBlades   I thought about getting that one. I think there i...   Mar 3 2013, 06:31 PM
michael7810   A year later and I just got around to notching the...   Jan 5 2015, 09:10 PM
Mueller   Being out of the air-cooled world for so long, at ...   Jan 6 2015, 10:26 AM
era vulgaris   Being out of the air-cooled world for so long, at...   Jan 6 2015, 10:54 AM
Mueller   Being out of the air-cooled world for so long, a...   Jan 6 2015, 10:59 AM
17 User(s) are reading this topic (17 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th November 2024 - 05:47 AM
