seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
(IMG:http://www.914world.com/bbs2/uploads/post-6-1163521889.jpg)
I get some of it, but I'm not seeing the whole picture. How does this all fit together? I know that the firewall mount welds to the firewall. I know that the v shaped piece with the arms mounts to the engine. What I don't see, or haven't seen up close and personal is how they mate together. Any help? thanks! |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
The big part gets welded to the firewall (bolted if you are lazy). The top of the shelf is mounted 7" above the body seam and centered in the engine bay. If you are using CIS you can drop it to about 6 1/2" to get clearance for the CIS system.
The nose piece (smaller big part) is bolted to the engine. The rubber mounts, sit over the holes in the top shelf and are attached with the short fasteners. Tighten them after the engine is in place as all they do is locate the motor mount. The big washer is placed over the long bolt and dropped through the mount (same as a 911 mounting). This keeps the bolt from pulling through the rubber under weight. I don't see those bolts in your kit, but they are the same as used on the 911 mount. When raising the engine into place, the outer ends of the engine mount are captured by the long bolts. Once in place, washer and nut and tighten. And when you install the engine, you cannot put the front engine tin on as it won't clear the mount. Install after engine is in. Need images? |
Lo-Fi Version | Time is now: 25th June 2024 - 07:56 PM |
