914-6 hand throttle linkage, More fun with ancient, cracked bushings! |
smj |
Jun 16 2012, 02:32 AM
"Dude, Steve from Berkeley." Group: Members Posts: 591 Joined: 28-August 05 From: Berkeley, CA Member No.: 4,691 Region Association: Northern California |
After my adventures with the shift linkage bushings (in this thread: http://www.914world.com/bbs2/index.php?showtopic=187814 ), the hand throttle in my -6 seemed to be disconnected. That is, after reassembly the position of the hand throttle seemed to have no effect on the idle.
Here's a view of the shifter/lever end of the hand throttle linkage from last weekend: I'm hoping that during final re-assembly I knocked something loose at the shifter/tunnel end, which I ought to be able to re-attach once I get in there in the morning. But if not, where the heck is the other end of that linkage -- under the gas tank? (I was about to check the PET when the computer I have it on decided to lock up as a special fuch-you-and-good-night just for me... A sign I should turn in and get some sleep, I think.) Thanks in advance, --Steve. |
sixnotfour |
Jun 16 2012, 10:03 AM
914 Wizard Group: Members Posts: 10,640 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Being a factory-6 on the pedal end of the rod it has or had a plastic radius end cap. If this fell off or deteriorated, It will cause the rod to be shorter and less effective. You can fix this by making the rod longer by adjusting it.
Attached image(s) |
Lo-Fi Version | Time is now: 26th November 2024 - 02:33 AM |
