corpselaurel |
Member ![]() ![]() Group: Members Posts: 90 Joined: 15-April 04 From: usa Member No.: 1,931 ![]() |
I am trying to figure out what to do about my suspension. I want dampening adjustability and height adjustability. I am not very familiar with products for the 914. If it was any other car I would go with something like Tein SS or H&R etc.
What coil overs do you guys use? Any full coil over setups available? (Threaded shocks not sleeves) Should I go with a koni shock threaded sleeve setup? I have a budget of about $800 give or take. I would like to get a new torsion bar too. Does it make any difference if I am doing a 5 lug conversion from a 911 in the front? Where did you get what you're using? |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
I am running the exact set-up Brad recommends.
It is an excellant upgrade from stock. Koni yellow's have an infinite adjustabilty on dampening. Full firm to full soft and anything in between. I'm using the Eibach 150# rear springs. It was very easy for Brad to lower the car exactly where I like like it, balanced perfectly with my weight in the seat. Along with the new tires this set-up is hard to beat. Thanks go out to Brad! (IMG:style_emoticons/default/beer.gif) Front and rear sway bars next. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:29 AM |
