Current measurements thru main fuse, fuses, total current from battery to operate x,x,x,x,x |
Tom |
Jun 19 2012, 01:54 AM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Been meaning to get this done and finally got around to it today. Wanted to make sure a 30 amp ATC style fuse would handle a 35 amp load without overheating the fuse holder and/or blowing.
Fuse was in-line with the 4 red wires from the battery. Ran 36.85 amps thru it for 15 minutes and removed to check the fuse. barely warm. Following are the results I got. engine running - 6.0 amps add radio - +1.1 amps add high beams - +10.6 amps add fog lights - +9.4 amps add emergency flashers + 5.25 amps add wipers - + 4.5 amps Total 36.85 amps My fresh air blower is not working and my heater blower is not installed but seperate testing on the heater blower was about 5 amps. I would expect the fresh air blower is about the same. Those with high output stereos would see more than my simple radio. I don't know how often one would have everything on at the same time, but some who purchased fuse block kits may be interested to know these results, especially those with the early cars that only have one large wire going to the front fuse panel area. Tom |
Mike Bellis |
Jun 19 2012, 10:32 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Electric motors go to full torque at start up. The starting amps are 3 times what you measure at RMS amperage.
I run a 200A fuse between my battery and disconnect. Works fine through the starter too. My electrical system is heavily modified. The 2 large wires that a 914 has from the battery to the dash are now fused and routed to the front trunk. I pulled the wires out of the loom and ran to inline fuses. I run a GM 1 wire alt with a #2awg cable to the starter. This completes the charging cycle. |
Lo-Fi Version | Time is now: 27th September 2024 - 06:24 PM |
