Oil temp sender and dry sump |
yeahmag |
Jun 20 2012, 10:37 AM
Advanced Member Group: Members Posts: 2,424 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Where would be the appropriate place to take oil temps from when converting to dry sump. My thoughts were either at the tank or utilizing one of the ports in my thermostat:
http://www.summitracing.com/parts/EAR-501ERL/ Opinions? -Aaron |
mrbubblehead |
Jun 20 2012, 02:01 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
i am using the same t-stat. my temp is taken right after the cooler, right before the oil goes to the mains.
yeahmag |
Jun 20 2012, 04:30 PM
So are using any of the 1/8" NPT ports to monitor anything? Mines going to be on the scavenge side, so I doubt the are useful for anything for me...
i am using the same t-stat. my temp is taken right after the cooler, right before the oil goes to the mains. |
mrbubblehead |
Jun 20 2012, 04:44 PM
So are using any of the 1/8" NPT ports to monitor anything? Mines going to be on the scavenge side, so I doubt the are useful for anything for me... i am using the same t-stat. my temp is taken right after the cooler, right before the oil goes to the mains. yes i am using all but one of them. i also had to add an aditional an fitting with an 1/8 port....(i wanted to monitor temps weather it was in bypass mode or not) oil pressure sender, oil pressure idiot light, and oil temp. i am using mine on the pressure side. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:37 AM |
