Red-Beard |
"Ya canna change the laws of Physics" ![]() ![]() ![]() Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None ![]() ![]() |
last time....
The engine was topping out at about 5000 RPM. This is what is supposed to be in the carb Original Settings Choke 27mm Aux Vin 4.5 Main Jet 1.05 Idle Jet 0.50 Air Idle 1.45 Emulsion Tube F1 Air Corr 2.00 Acc Pump 0.50 Needle valve 1.75 What I found: Choke 32mm Aux Vin 4.5 Main Jet 1.05 Idle Jet 0.60 Air Idle 1.80 Emulsion Tube F1 Air Corr 2.00 Acc Pump 0.50 Needle valve 1.75 Hmmm. Maybe this is why I couldn't get it to idle worth a crap. It's jetted for a 2.2S. Soooooo, now it is much more closely jetted. OMG!!! This thing pulls like a rocket! I gave a late Mustang a run for his money. Now the tranny linkage is adjusted right (Physcian heal thyself!). This MOFO is amazing. And there is more torque than the clutch can handle. It still has some oil from the previous engine. Around 4000-5000 rpm at WOT in the upper gears, the clutch will slip. Guess I'm doing the clutch tomrrow. I think I need to buy a G meter or maybe take the car out for a dyno run. But I am guessing the 210 HP number is correct, at least. (IMG:style_emoticons/default/wacko.gif) |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,003 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
Yup, put yer foot down and "poof" you dissapear in a cloud of blue smoke like a rocket. (IMG:style_emoticons/default/rolleyes.gif)
Lo-Fi Version | Time is now: 28th June 2024 - 11:51 AM |
