What is the proper/preferred suspension height? (front/back) |
skaufmann |
Jul 9 2012, 08:59 PM
Blissfully Ignorant Group: Members Posts: 103 Joined: 26-May 11 From: San Diego - College Area Member No.: 13,123 Region Association: Southern California |
I got my 72 on her feet again after 13 months on stands. My first observation is she's sagging a bit in the rear (yeah what should I expect for a 40-year old).
What I have is the rear tire sits about 1 inch into the well. In other words, looking at it broad-side about 1 inch of the top of the tire is covered by the wheel well. The front tire is opposite where there's about 1 inch of space above the tire to the wheel well. This definitely gives it a taildragger look. How do I want it to be? Balanced so its even front and back or do I want the front a bit lower? Also, where is the best point to measure from? I haven't looked closely yet but in my head I'm thinking from the ground to somewhere on the suspension that stays with the body. Thanks ahead of time for all your responses. |
r_towle |
Jul 10 2012, 11:37 AM
Custom Member Group: Members Posts: 24,680 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If you have a haynes manual it shows how to figure out the proper ride height for the front.
From there, I typically will measure the bottom of the rocker in the front and rear, then make the rear of the rocker about 1/4 inch higher than the front of the rocker. I have adjustable rear perches, so in reality I set the back first, then use a tape measure and measure the rear of the rocker to ground. I then cut a block of wood that is 1/4 inch shorter and set that under the front of the rocker. I can then see the block while turning the front adjuster. After I get it where I want, I align it and if required, corner balance it. I move my ride height at least twice per year...winter and summer settings...winter is higher due to the tires and snow. I dont corner balance it anymore...I just align it each time. Anytime you raise or lower the car, you need to redo the alignment. rich |
Lo-Fi Version | Time is now: 6th January 2025 - 08:35 PM |
