Britain Smith |
Nano Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 ![]() |
Well...the last couple of days the grinding of my tranny in first and reverse got out of hand. It appears that the clutch was not fully engaging when I pushed it in even though Brad and I recently went through the painful procedure of welding the clutch tube and installing a new clutch cable. I believe that the main issue now is the pedal assembly and all the original plastic bushings. With a shortage of time before to install the bronze bushing kit before the WCC this weekend, I opted to switch out the orginal pedal assembly with the one from my now completely dissassembled 912. Although it is painted red, it has the complete bronze bushing kit installed and fit right into the teener. All I have left to do is adjust the throttle cable so it doesn't rev to 4K, adjust the clutch so it doesn't do any more damage, and adjust the shaft for the master cylinder so the rear brakes don't lock up prematuraly. Does anyone have any suggestions on these three tasks? Why do things always have to break at the wrong times...Murphy's Law I guess.
-Britain |
nebreitling |
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 ![]() |
QUOTE(SirAndy @ Jun 2 2004, 01:26 PM) worn out bushing means wrong angle (not 90 deg) on the pivot shaft, means automatic clutch adjustment on the fly (usually for the worse), depending on the load on the worn bushing. cool, thanks. that clears it up for me |
Lo-Fi Version | Time is now: 25th June 2024 - 01:08 AM |
