> Nader's Nightmare...and mine too build thread, 4/6/14 Update.
914coop
post Jun 20 2011, 10:23 PM
Well after over two months it has finally arrived. (IMG:style_emoticons/default/piratenanner.gif) Guessing a lot of you are already familiar with this car. Previous threads are 914-6 Carrma and WOW, my "solid" car aint so solid, but now it is solid!, It is off jack stands!!!.
I bought this car for two reasons.
First, back on moaners day 2010 my 76' was rear ended. Got a rear clip for it and was going to have Area 51 Werks straiten it out and put on my AA steel flares. This car handled most of that need. (flares will still need to be done)
Second, I was planning on doing the five lug conversion. Had the parts to convert the 914 suspension to a five lug. (Modified 914-4 parts) This car was a huge upgrade as T.C. had converted it to a 911 setup both front and rear.
Those of you who know me already know this is a car for my son Dan, as I am legally blind and for some reason the stare of Minnesota would rather I not operate a vehicle on the roads..... (IMG:style_emoticons/default/biggrin.gif)
After some thought and checking Dan's finances (Porsche Purists Skip this paragraph) We have decided to put a 1966 Corvair 180 turbo in it. This engine will be modified slightly. Heads will have stainless valves and angled exhaust ports. Cam has been custom made by Cower Cams for more torque in the mid range and high end. Just waiting on the rebuild kit from Corvair Underground. We also will be changing the draw through Turbo to a dual carb blow through system. We have asked Steve Goodman (Corvair Guru) for advice as we started down this path.
Set a goal to have it road worthy by the RRC this fall.
Here are some pictures, sorry my son took the pictures and can not seem to center the subject.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i384.photobucket.com-9514-1308630203.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i384.photobucket.com-9514-1308630203.2.jpg)
Still searching for a name, suggestions welcome.
Dr Evil
post Jul 16 2012, 09:10 PM
Send me your transmission!
Where is your return going?
I may be turning the key on my science project this weekend as well. Good luck!
914coop
post Jul 17 2012, 06:20 AM
QUOTE(Dr Evil @ Jul 16 2012, 07:10 PM) *
Feed is going out through where pressure sender was. I have added AN adapter with gauge fitting there. Welded shut the hole that went to the oil filter on that side. Return will come back from the remote oil filter and external cooler to the other hole left when I cut off the filter connection. Welded a AN fitting there also. Will verify the flow when I prime the system before attempting too start.
914coop   Nader's Nightmare...and mine too build thread   Jun 20 2011, 10:23 PM
carr914   Irv, since it's getting a Corvair engine, I...   Jun 21 2011, 05:00 AM
914coop   Irv, since it's getting a Corvair engine, I...   Jun 21 2011, 08:47 AM
kevin311   Congrats on the car. I went to look at it and it w...   Jun 21 2011, 07:18 AM
PanelBilly   What prompted the covair engine?   Jun 21 2011, 08:08 AM
914coop   What prompted the covair engine? Few things, co...   Jun 21 2011, 09:26 AM
Tom_T   What prompted the covair engine? Maybe Doc Evil...   Jun 21 2011, 10:02 AM
914coop   What prompted the covair engine? Maybe Doc Evi...   Jun 21 2011, 02:21 PM
chuckc   How fantastic! Congratulations. I wanted this ...   Jun 23 2011, 05:38 PM
914coop   Thanks T.C. for the nickname. Well after 5 months...   Nov 5 2011, 10:00 AM
rick 918-S   :assimilate: I'll post some larger photos if I...   Nov 5 2011, 10:41 AM
914coop   :assimilate: I'll post some lager photos if I...   Nov 5 2011, 06:08 PM
Dr Evil   :) If I can offer info, advise, or links to good ...   Nov 5 2011, 10:56 AM
sixnotfour   hopefully it was a 1964 spyder so you got the 164c...   Nov 5 2011, 08:03 PM
914coop   hopefully it was a 1964 spyder so you got the 164...   Nov 5 2011, 08:25 PM
Dr Evil   That is a better engine. If you want to put more o...   Nov 5 2011, 08:42 PM
914coop   That is a better engine. If you want to put more ...   Nov 6 2011, 08:40 AM
rick 918-S   Here ya go guys. Here's a couple from the firs...   Nov 5 2011, 10:53 PM
Dr Evil   In a 914 that will be plenty fun and cheap to main...   Nov 6 2011, 09:33 AM
sixnotfour   If you going to run the YH rochester carb spirite...   Nov 6 2011, 10:22 AM
914coop   If you going to run the YH rochester carb spirit...   Nov 6 2011, 05:05 PM
carr914   Thanks T.C. for the nickname. We found 255x60x15...   Nov 6 2011, 06:12 PM
914coop   :D Glad you found some rubber for those wheel...   Nov 6 2011, 10:17 PM
rick 918-S   Irv and Dan were here today. We worked on the engi...   Nov 6 2011, 11:00 PM
914coop   Looking very nice Rick!   Nov 7 2011, 07:06 PM
SUNAB914   Wow Coop, that thing has one fat ass! keep pos...   Nov 7 2011, 09:21 AM
914coop   Wow Coop, that thinghone at ass! keep posting...   Nov 7 2011, 07:29 PM
Drums66   .......Ya, the Corsa turbo shits & gits.....bu...   Nov 8 2011, 05:47 PM
rick 918-S   Starting to shrink the extra metal from reversing ...   Nov 12 2011, 02:10 PM
914coop   Dan and myself where up to Area 51 Weeks Sunday. D...   Nov 15 2011, 12:14 AM
914coop   Engine pieces are shipped and should be here by We...   Nov 20 2011, 03:59 PM
rick 918-S   Engine pieces are shipped and should be here by W...   Nov 20 2011, 06:18 PM
rick 918-S   Ran out of wire for my mig and gas for my tig so I...   Nov 20 2011, 08:26 PM
914coop   Looking great Rick! :thumbsup: :thumbsup: :...   Nov 21 2011, 12:08 PM
914coop   Engine parts arrived last Tuesday :Qarl: , althoug...   Dec 5 2011, 09:00 PM
rick 918-S   Engine parts arrived last Tuesday :Qarl: , althou...   Dec 5 2011, 10:27 PM
914coop   Well got the pistons and rods back Friday. Got rin...   Dec 11 2011, 03:04 PM
rick 918-S   Well got the pistons and rods back Friday. Got ri...   Dec 11 2011, 03:48 PM
914coop   Well got the pistons and rods back Friday. Got r...   Dec 11 2011, 07:08 PM
rick 918-S   Lots of bumping and grinding yet but here's a ...   Dec 12 2011, 12:04 AM
914coop   Looking good Rick. :thumbsup: :thumbsup: :welder...   Dec 12 2011, 01:14 PM
rick 918-S   More bumping and shaping. the last couple nights. ...   Dec 15 2011, 12:07 AM
914coop   Engine shop call this morning and I stopped by on ...   Dec 15 2011, 01:51 PM
rick 918-S   What pistons do you have? Probe? Like in Ford Prob...   Dec 15 2011, 04:51 PM
Dr Evil   What pistons do you have? Probe? Like in Ford Pro...   Dec 15 2011, 05:43 PM
monkeyboy   What pistons do you have? Probe? Like in Ford Pro...   Dec 17 2011, 03:08 AM
rick 918-S   RE: Nader's Nightmare...and mine too build thread   Dec 17 2011, 01:05 AM
914coop   Sorry work was a ..... This week, everyone trying ...   Dec 17 2011, 12:15 PM
rick 918-S   These fronts are going to be a bitch to fit. As I ...   Dec 17 2011, 01:02 PM
jmill   Progress looks great. It must be nice having a he...   Dec 17 2011, 04:23 PM
914coop   Progress looks great. It must be nice having a h...   Dec 17 2011, 05:01 PM
rick 918-S   Yep, Very mild here. :D Here's a sample of t...   Dec 18 2011, 12:44 AM
rick 918-S   The flares were too close to the tires so I raised...   Dec 24 2011, 12:28 AM
Dr Evil   Wow!   Dec 24 2011, 09:39 AM
914coop   Wow! :agree: WOW!!!!   Dec 24 2011, 10:21 AM
sixnotfour   This angle is :first:   Dec 24 2011, 11:27 AM
rick 918-S   Nader's Nightmare is going home! Nice day ...   Jan 14 2012, 10:54 AM
kevin311   Thats the first time I've seen a slant nose co...   Jan 14 2012, 11:02 AM
dlee6204   Nice job Rick!   Jan 14 2012, 11:05 AM
914coop   Nice job Rick! :agree: :worship: Can...   Jan 14 2012, 11:29 AM
carr914   Nader's Nightmare is going home! Nice day...   Jan 14 2012, 11:07 AM
rick 918-S   Nader's Nightmare is going home! Nice da...   Jan 15 2012, 05:06 PM
KELTY360   Never ceases to amaze me what I'll see @914Wor...   Jan 14 2012, 11:10 AM
914coop   Rick dropped the car off this afternoon, he went w...   Jan 14 2012, 05:20 PM
sixnotfour   Slope Nose Revival I wonder how some up side dow...   Jan 14 2012, 05:44 PM
rick 918-S   Hey Irv, I sent you an email with the phone numbe...   Jan 15 2012, 06:03 PM
914coop   Defiantly will take a ride with you driving. Ke...   Jan 15 2012, 09:52 PM
Cairo94507   Wow Wow Wow! Rick has some serious metal skill...   Jan 16 2012, 07:25 AM
914coop   Wow Wow Wow! Rick has some serious metal skil...   Jan 16 2012, 10:59 AM
914coop   Rings are here..... :Qarl: :Qarl: Will be assem...   Feb 25 2012, 12:22 PM
914coop   Been offline for a few months due to health issue....   May 20 2012, 02:27 PM
Dr Evil   Nice! If you have a need, I have some almost ...   May 20 2012, 02:43 PM
914coop   Nice! If you have a need, I have some almost...   May 20 2012, 04:07 PM
Dr Evil   Nice! If you have a need, I have some almos...   May 20 2012, 08:12 PM
Qarl   Really like the corvair motor. An American flat-...   May 20 2012, 04:21 PM
rick 918-S   Looking good Irv. Nice to see the progress!   May 20 2012, 04:50 PM
Chris H.   Wow Rick, that thing looks amazing. Must have bee...   May 21 2012, 09:42 AM
carr914   Wow Rick, that thing looks amazing. Must have be...   May 21 2012, 10:38 AM
Chris H.   I had it before Irv. I had an opportunity to bu...   May 21 2012, 12:11 PM
carr914   I had it before Irv. I had an opportunity to b...   May 21 2012, 01:24 PM
914coop   Ok engine is together minus turbo and carb's. ...   Jun 9 2012, 09:23 PM
Dr Evil   Nice. You are not moving the oil filter? I think I...   Jun 9 2012, 09:31 PM
rick 918-S   Nice progress! I wanted to come down and help ...   Jun 9 2012, 09:50 PM
914coop   Have the adapter to replace the oil cooler and can...   Jun 10 2012, 11:20 AM
r3dplanet   I have a Corvair motor that I bought for this conv...   Jun 10 2012, 12:12 PM
914coop   I have a Corvair motor that I bought for this con...   Jun 10 2012, 02:42 PM
Dr Evil   The wrist pins are interference fit and different ...   Jun 10 2012, 05:36 PM
914coop   The wrist pins are interference fit and different...   Jun 10 2012, 07:40 PM
914coop   Well engine is in the car, not fully secure but in...   Jun 30 2012, 11:04 AM
Dr Evil   I can take a pic of my oil setup if you like. Nice...   Jun 30 2012, 11:34 AM
914coop   I can take a pic of my oil setup if you like. Nic...   Jun 30 2012, 12:16 PM
rick 918-S   Try these diagrams. http://www.pelicanparts.com/...   Jun 30 2012, 11:38 AM
914coop   Try these diagrams. http://www.pelicanparts.com...   Jun 30 2012, 12:23 PM
rick 918-S   We should be around. Not sure you will have time t...   Jun 30 2012, 01:14 PM
Dr Evil   Here is my setup. I have the lines going to a ther...   Jul 1 2012, 06:52 PM
914coop   Thanks, basically what I came up with yesterday. I...   Jul 1 2012, 09:48 PM
914coop   Oil filter mount modified. http://www.914world.c...   Jul 16 2012, 09:07 PM
Dr Evil   Where is your return going? I may be turning the ...   Jul 16 2012, 09:10 PM
914coop   Where is your return going? I may be turning the...   Jul 17 2012, 06:20 AM
rick 918-S   :popcorn:   Jul 16 2012, 10:21 PM
- Lo-Fi Version Time is now: 20th April 2025 - 06:45 AM
