What Relay Goes Here? |
tomeric914 |
Jul 19 2012, 09:21 PM
One Lap of America in a 914! Group: Members Posts: 1,263 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
I'm guessing that it's for an intermittent wiper relay because it ties into the wiper motor and the wiper stalk has 4 positions including off. One position currently does nothing. This is on a '74 914.
If it is for the intermittent relay, what is the part number? Wait, I might have found it. Is it 111 955 531? |
mrbubblehead |
Jul 21 2012, 06:23 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
hmmm??? my car is a 74 also, and i dont have a relay. mine appears to be wired directly to the switch. and i couldnt find a relay in the wireing diagram either. it would be easy enuff to wire one in though.
SirAndy |
Jul 21 2012, 07:10 PM
Resident German Group: Admin Posts: 41,963 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
i couldnt find a relay in the wireing diagram either. I'm not surprised since it was optional equipment. Not just the relay, but the whole harness with the socket was optional. (IMG:style_emoticons/default/popcorn[1].gif) PS: I have mounted the stock harness in my car, and if i recall correctly, the wire for the trigger is in the main harness but taped up somewhere near the drivers side air flap behind the brake fluid reservoir. The other wires from the harness go in line with the wiper motor connections. It's pretty much plug & play to install. |
mrbubblehead |
Jul 21 2012, 10:59 PM
i couldnt find a relay in the wireing diagram either. I'm not surprised since it was optional equipment. Not just the relay, but the whole harness with the socket was optional. (IMG:style_emoticons/default/popcorn[1].gif) PS: I have mounted the stock harness in my car, and if i recall correctly, the wire for the trigger is in the main harness but taped up somewhere near the drivers side air flap behind the brake fluid reservoir. The other wires from the harness go in line with the wiper motor connections. It's pretty much plug & play to install. sir andy, is the "trigger" brown with a black stripe? labeled T1a on the wiring diagram? it comes from the wiper switch? it must be..... |
Lo-Fi Version | Time is now: 8th January 2025 - 09:16 PM |
