Flywheel question |
Flywheel question |
jmargush |
Jul 22 2012, 05:00 PM
Member Group: Members Posts: 463 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I have a flywheel off of the 2.0 that I am rebuilding and it has been machined down approx. 3.2mm from what I measure on other flywheels I have off of 1.8 engines.
The step down to the clutch surface was machined the same amount but I was curious if there are any concerns with using a flywheel that has been machined this much? One issue I did experience when I was dismantling the engine is you can't get a socket around the bolts that hold the clutch on, so i was considerinf using a cap (allen) bolt. |
Lo-Fi Version | Time is now: 26th June 2024 - 05:55 AM |
