Coil over options - what do you use?, coilover setup, torsion bar, - sources |
corpselaurel |
May 27 2004, 01:38 PM
Member Group: Members Posts: 90 Joined: 15-April 04 From: usa Member No.: 1,931 |
I am trying to figure out what to do about my suspension. I want dampening adjustability and height adjustability. I am not very familiar with products for the 914. If it was any other car I would go with something like Tein SS or H&R etc.
What coil overs do you guys use? Any full coil over setups available? (Threaded shocks not sleeves) Should I go with a koni shock threaded sleeve setup? I have a budget of about $800 give or take. I would like to get a new torsion bar too. Does it make any difference if I am doing a 5 lug conversion from a 911 in the front? Where did you get what you're using? |
corpselaurel |
Jun 4 2004, 03:18 PM
The site doesn't really mention reinforcment. It just says "Once installed, they are very strong and allow for ample camber and caster adjusting."
Seems like it is more for adjustibility than strength. Not to mention they say that they are for a 911. (I know they will work with the 914, I am just unsure about the reinforcing that is needed.) Anyone run coil overs with out reinforcing? What about a high spring rate on stiff shocks? |
Lo-Fi Version | Time is now: 26th June 2024 - 09:26 AM |
