Running Hot on the Highway |
NJ914Guy |
Jul 25 2012, 08:22 PM
Member Group: Members Posts: 150 Joined: 30-December 10 From: Deptford, NJ Member No.: 12,546 Region Association: MidAtlantic Region |
My car is a 1973 914 2.0 running dual Weber 40 carbs, an Aircooled.net SVDA vac advance distributor (vac port connected to dual carbs) and a Pertronix electronic ignition module.
Here in NJ, on a 80-90 degree day, the car runs great on the back roads ranging from 30-45 MPH. Using the dip stick temp gauge, she runs around 180-195 for oil temp. If I take her up ont the highway and run the car at 65-80 MPH for 10-20 minutes, the temp will run up to 220-240, based on the outside air temps, which seems too hot. I assume that since I am fine on the back roads, my flaps and fan are clear and working fine? I do have 100% of the factory tins in place, and from 180-240 degrees, the car runs strong at all temps. I am thinking that I have a problem and would like to rule out some things. Here's my list of things to try. Please feel free to comment or make additional suggestions. 1. Change oil. I am running 10W-30 now. Have some fresh Brad Penn 20W-50 on hand. Could an oil change help? 2. Drop the oil screen and check for any sludge or blockage which may be impacting oil flow. 3. Check timing on the SVDA dizzy. I am wondering if it's advancing a little too much on the highway? Per John's instruction, when we installed the dizzy we set timing to: 38-45 Total Advance (hose connected) @ 3500 RPM. 4. Pull spark plugs and check for lean conditions. 5. Check carbs and idle jets. Not sure what's in there, but I hear that I want idle jets of 50. |
NJ914Guy |
Jul 26 2012, 08:11 AM
Thank you, Chris!
Lo-Fi Version | Time is now: 18th June 2024 - 07:16 AM |
