stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I am getting ready to put my short block together and I have what appears to be a fairly new crank.
Main bearing journals: 2.361. The bearings appear to be new unused STD-STD. When I put on the main bearing that goes directly beneath the cam gear dry and wiggle it I get ~4 thousandths "wiggle" when measured with a dial indicator stuck to the flywheel. Does that sound correct? Would that be considered two thousandths bearing clearance (2 on each side = 4)? Stu |
stugray |
Yes I have heard of plastigauge, but you cannot use it in this application because the two bearings I am trying to measure are the full circumference bearings. There is no way to get it in there and then clamp.
That would work for the rod bearings or the center bearing. Thanks though. Stu |
Lo-Fi Version | Time is now: 26th April 2025 - 08:36 PM |
