stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
I am getting ready to put my short block together and I have what appears to be a fairly new crank.
Main bearing journals: 2.361. The bearings appear to be new unused STD-STD. When I put on the main bearing that goes directly beneath the cam gear dry and wiggle it I get ~4 thousandths "wiggle" when measured with a dial indicator stuck to the flywheel. Does that sound correct? Would that be considered two thousandths bearing clearance (2 on each side = 4)? Stu |
stugray |
The crank is bolted to the flywheel sitting on the bench vertical.
I put the magnetic base dial indicator on the flywheel and measure the total movement of the main bearing (opposite end of the crank) with the bearing dry. I dont have an inside micrometer to measure the bearing so this was just a sanity check. It seems a little more loose than normal, but it is very hard to judge. Of course once you put lube on the bearing and put it on it doesnt seem to have a lot of slop. Stu |
Lo-Fi Version | Time is now: 26th April 2025 - 08:22 PM |
