bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
As some of you already know, I'm doing a V8 conversion in my 914 with an LT1 from a 1993 firebird. The cam driven waterpump sticks out the front and gets in the way in a big way. In order to avoid extreme firewall modifications, I came up with a crazy idea... I'll install an electric waterpump kit in the stock waterpump housing... and mount the sucker up by the radiator! It will require a couple of custom flanges, and a couple hose "Ys" but it should work.. with one possible exception. The thermostat is in the water pump, and it's a fancy bypass thermostat. instead of blocking the water until it warms up, it bypasses the radiator until it warms up, and once it warms up it closes the bypass and opens the radiator. I'm worried that the engine may overheat before the thermostat has a chance to open, because it's farther away and will react later than usual. Has anyone ever done anything even remotely like this? Am I nuts?
--Royce |
bondo |
Cool, thanks guys. The reason I want an LT1 is the nice wide and smooth torque range. I don't like tuning carbs, and I can never get them to run good cold. The LT1 runs great at pretty much all rpm ranges, and at all temperatures. I'd go LS1 if I could afford it, but I can't. I got the LT1 for $1000 with all accessories and aluminum heads. I plan to turn the intake around and put the air cleaner in the trunk. I drive with my seat all the way back, so I really don't want to mess with the firewall at all. The optispark will fit into the depression in the firewall, but the waterpump is much too wide. The inline thermostat sounds appealing, but I don't know if the reverse cooling setup would be 100% compatible with it.
--Royce |
Lo-Fi Version | Time is now: 18th June 2024 - 06:37 AM |
