Fuel pump relay location, 1974 D-Jet |
mittelmotor |
Aug 10 2012, 12:09 AM
Member Group: Members Posts: 334 Joined: 21-May 12 From: SoCal Member No.: 14,464 Region Association: None |
Hi guys,
I tried searching a bit, but couldn't find this exact info. Where is the fuel pump relay on a 1974 914 2.0 located? I'm doing a V-8 conversion, so I sold the driver's-side relay board in the engine compartment with the 2.0-liter. I hope it wasn't on there. (IMG:style_emoticons/default/sad.gif) Thanks! |
germanv82000 |
Aug 10 2012, 09:55 AM
scott pickering Group: Members Posts: 26 Joined: 19-July 06 From: stockton, ca Member No.: 6,464 Region Association: Northern California |
If you are doing a v8 conversion you can wire the fuel pump to a switched circuit of your choice. Carbureted? Fuel injected pump is going to put out probably too much fuel pressure.
Lo-Fi Version | Time is now: 28th October 2024 - 07:13 AM |
