Woody |
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region ![]() |
Well its time to upgrade the shocks on my car. It is primarily used for AX with a trackday thrown in. Currently the car has T struts, 21mm torsion bars, 19mm sway bar, and monoball strut mounts and 180 pound springs in the back. All the bushings have been replaced with delrin. I would like to lower the car a little bit more but am limited with the current T struts. I was intending to go with Koni or Bilstein inserts and shocks with a coil over kit on the rear but then I happened across these which are still in the budget but barely.
http://www.tarett.com/items/914-products/9...strt-detail.htm http://www.tarett.com/items/914-products/9...rshk-detail.htm I do have a set of calipers that I should be able to use since mine currently have the 3" spacing. Will the T hubs work on the RSR spindles? Any thoughts on this? Should I just keep it simple and go with the Konis? |
Woody |
Are those adjustable? I would be looking for something adjustable to play with. No they're not but I've heard the konis are not consistent. Next step above that is way over my budget. Save some trial and error - and $ and find out what the top guys are using. That's kinda why I'm asking here. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 02:29 AM |
