> ITB project, Honda VFR 800 ITBs
kevin311
post Aug 17 2012, 11:25 AM
I've been running Megasquirt II for a while now on my 71 1.7 with the stock D-jet components and it has been running well. But everything is looking tired in the engine bay and I am planning on taking out the engine to clean everything up and install SS fuel lines.
Then I remembered seeing a video youtube with an australian guy reviewing his 914 and he mentioned having GSXR ITBs on his car. Sounds like a fun project to me so I started researching and think I have found an even better solution.
The throttle bodies I found are from a 2001 Honda VFR800. The bike is a V4 so the TBs and fuel rails are already split into pairs, and have a linkage that connects both. They have 37mm throats, and came with the throttle position sensor, fuel pressure regulator , injectors and and all the wiring and connectors. Also the brackets on the sides already have a tab for throttle cable.
The injectors are high impedance so I wont have to run PWM on Megasquirt anymore and hopefully can get an even finer tune.
I'm also thinking about switching the PCs for 96mm, but I think that will wait until later, but you never know this started out as an engine cleaning...
The only things I need to figure out are the flow rate of the injectors, where I'm going to hook up the IAT sensor, and will need to build a vacuum plenum. Also these injectors run at 36 psi, can the stock fuel pump handle that or do I need to look for another solution?
Here are some pics, check out how close the spacing is for weber manifolds.
Please excuse the dirt. I still haven't cleaned them up.
This is gonna be fun. (IMG:style_emoticons/default/beerchug.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1345224315.1.jpg)
(IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03555.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1345224325.2.jpg)
(IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03552.jpg)
(IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03558.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1345224346.3.jpg)
(IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03559.jpg)
mrbubblehead
post Aug 17 2012, 04:09 PM
Twodollardoug
seems like i recall someone over on the type4um doing something very similar. but he was having a problem with his throttle bodies staying put. like they were coming loose and popping out of the boots. i wonder if you could fab up an aluminum flange and weld the throttle bodies directly to the flange. then bolt them to the manifold. then they would be hard mounted.
kevin311   ITB project   Aug 17 2012, 11:25 AM
Dr Evil   Always interesting :popcorn:   Aug 17 2012, 01:41 PM
mrbubblehead   :popcorn:   Aug 17 2012, 02:02 PM
DBCooper   I had the GSXR TB's back in the day. I actual...   Aug 17 2012, 02:06 PM
kevin311   :agree: The best part is the whole assembly was ...   Aug 17 2012, 03:59 PM
mrbubblehead   did you happen to get the mounting boots? looks li...   Aug 17 2012, 04:02 PM
mrbubblehead   seems like i recall someone over on the type4um do...   Aug 17 2012, 04:09 PM
kevin311   The plan is to fab up some adapter flanges to moun...   Aug 17 2012, 04:33 PM
ChrisNPDrider   :popcorn:   Aug 17 2012, 06:59 PM
rick 918-S   Love it! :popcorn: Easy to make an adaptor to ...   Aug 17 2012, 07:21 PM
euro911   Looks interesting. :popcorn: I don't know mu...   Aug 17 2012, 08:11 PM
kevin311   I got the ITBs mocked up on an engine today. I fou...   Nov 25 2012, 02:32 PM
Sleepin   Wow! Amazing project! Are the Harley ada...   Nov 25 2012, 02:48 PM
ConeDodger   I'm not sure how well this will work. I have t...   Nov 25 2012, 03:42 PM
Dave_Darling   If so, you had about 1.75" of throttle plate...   Nov 25 2012, 06:50 PM
DBCooper   If so, you had about 1.75" of throttle plat...   Apr 10 2013, 11:15 AM
ConeDodger   To answer your questions, yes, the stock pump on m...   Nov 25 2012, 03:48 PM
kevin311   I had similar thoughts about the throttles when I ...   Nov 25 2012, 04:47 PM
ConeDodger   I thought of that too. Carbs cover their sins in m...   Nov 25 2012, 04:59 PM
Dr Evil   Dont forget to use a phenolic spacer to soak up th...   Nov 25 2012, 06:25 PM
euro911   Dont forget to use a phenolic spacer to soak up th...   Nov 25 2012, 06:42 PM
wndsrfr   Super cool looking setup but I'm concerned wit...   Nov 25 2012, 06:32 PM
aircooledtechguy   Super cool looking setup but I'm concerned wi...   Nov 25 2012, 10:22 PM
FourBlades   Go go go! Love how cheap the tbs are... A gr...   Nov 25 2012, 06:42 PM
rdauenhauer   I had similar thoughts about the throttles when I...   Nov 25 2012, 07:21 PM
aircooledtechguy   I don't think you'll need to be too worrie...   Nov 25 2012, 08:28 PM
kevin311   So the project took a back shelf for a while becau...   Apr 10 2013, 10:25 AM
Mark Henry   Very cool, I'm about to do the same thing on m...   Apr 10 2013, 11:07 AM
monkeyboy   [quote name='Dave_Darling' post='1773574' date='N...   Apr 10 2013, 02:09 PM
rick 918-S   Just purchased a set of these VFR ITB's off eb...   Apr 10 2013, 07:39 PM
ThePaintedMan   Kevin, Three things. 1 - I'm glad that it...   Apr 10 2013, 09:34 PM
DBCooper   Those guys wad up bikes pretty frequently, so thos...   Apr 10 2013, 10:45 PM
ottox914   That is going to be amazing when done. Keep the u...   Apr 13 2013, 07:24 AM
kevin311   Thanks everyone! :beer2: Just a quick update...   May 12 2013, 09:57 AM
moparrob   Thanks everyone! :beer2: Just a quick updat...   May 12 2013, 01:13 PM
Dr Evil   Re-following this :D :popcorn:   May 12 2013, 05:58 PM
kevin311   Just a quick update for those interested. I finis...   Jul 14 2013, 03:47 PM
billh1963   Really looking forward to seeing how this works ou...   Jul 14 2013, 04:37 PM
aircooledtechguy   Looking good. . . :popcorn:   Jul 14 2013, 07:47 PM
rick 918-S   Excuse my ignorance I'm old so I do not know t...   Jul 14 2013, 10:03 PM
aircooledtechguy   Excuse my ignorance I'm old so I do not know ...   Jul 14 2013, 10:56 PM
Dave_Darling   Intake Air Temp sensor. Dunno why it's out th...   Jul 14 2013, 10:58 PM
kevin311   Yea I couldn't find a spot underneath that wou...   Jul 15 2013, 05:45 AM
craigrobbo   I came here from another forum with a similar buil...   Nov 20 2013, 04:05 AM
Mark Henry   I have a similar thread somewhere, I need to updat...   Nov 20 2013, 07:07 AM
craigrobbo   I have a similar thread somewhere, I need to upda...   Nov 20 2013, 03:45 PM
Mark Henry   [quote name='Mark Henry' post='1959555' date='Nov...   Nov 21 2013, 07:47 PM
kevin311   No updates lately. This project has been shelved f...   Nov 20 2013, 06:15 PM
2mAn   Bummed you didnt get a chance to finish, this is e...   Nov 21 2013, 04:44 PM
914_teener   I was interested in these working at all. Fun proj...   Nov 21 2013, 05:09 PM
rick 918-S   Any up dates?   Feb 3 2014, 04:30 PM
ClayPerrine   This is a cool project, but I think that you are g...   Feb 3 2014, 05:11 PM
Mark Henry   This is a cool project, but I think that you are ...   Feb 3 2014, 08:31 PM
r_towle   This is a cool project, but I think that you are...   Feb 3 2014, 08:35 PM
- Lo-Fi Version Time is now: 20th April 2025 - 07:35 PM
