> ITB project, Honda VFR 800 ITBs
kevin311
post Aug 17 2012, 11:25 AM
I've been running Megasquirt II for a while now on my 71 1.7 with the stock D-jet components and it has been running well. But everything is looking tired in the engine bay and I am planning on taking out the engine to clean everything up and install SS fuel lines.
Then I remembered seeing a video youtube with an australian guy reviewing his 914 and he mentioned having GSXR ITBs on his car. Sounds like a fun project to me so I started researching and think I have found an even better solution.
The throttle bodies I found are from a 2001 Honda VFR800. The bike is a V4 so the TBs and fuel rails are already split into pairs, and have a linkage that connects both. They have 37mm throats, and came with the throttle position sensor, fuel pressure regulator , injectors and and all the wiring and connectors. Also the brackets on the sides already have a tab for throttle cable.
The injectors are high impedance so I wont have to run PWM on Megasquirt anymore and hopefully can get an even finer tune.
I'm also thinking about switching the PCs for 96mm, but I think that will wait until later, but you never know this started out as an engine cleaning...
The only things I need to figure out are the flow rate of the injectors, where I'm going to hook up the IAT sensor, and will need to build a vacuum plenum. Also these injectors run at 36 psi, can the stock fuel pump handle that or do I need to look for another solution?
Here are some pics, check out how close the spacing is for weber manifolds.
Please excuse the dirt. I still haven't cleaned them up.
This is gonna be fun. (IMG:style_emoticons/default/beerchug.gif)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1345224315.1.jpg)
(IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03555.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1345224325.2.jpg)
(IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03552.jpg)
(IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03558.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i694.photobucket.com-11752-1345224346.3.jpg)
(IMG:http://i694.photobucket.com/albums/vv310/Kevin31188/DSC03559.jpg)
rick 918-S
post Aug 17 2012, 07:21 PM
Hey nice rack! -Celette
Love it! (IMG:style_emoticons/default/popcorn[1].gif) Easy to make an adaptor to transition that set onto the manifolds! That cast in piece between the TB's would make for a solid mount to hold them to the boots. (IMG:style_emoticons/default/beerchug.gif) 37mm should flow enough volume to feed a 1.7 air pump.
kevin311   ITB project   Aug 17 2012, 11:25 AM
Dr Evil   Always interesting :popcorn:   Aug 17 2012, 01:41 PM
mrbubblehead   :popcorn:   Aug 17 2012, 02:02 PM
DBCooper   I had the GSXR TB's back in the day. I actual...   Aug 17 2012, 02:06 PM
kevin311   :agree: The best part is the whole assembly was ...   Aug 17 2012, 03:59 PM
mrbubblehead   did you happen to get the mounting boots? looks li...   Aug 17 2012, 04:02 PM
mrbubblehead   seems like i recall someone over on the type4um do...   Aug 17 2012, 04:09 PM
kevin311   The plan is to fab up some adapter flanges to moun...   Aug 17 2012, 04:33 PM
ChrisNPDrider   :popcorn:   Aug 17 2012, 06:59 PM
rick 918-S   Love it! :popcorn: Easy to make an adaptor to ...   Aug 17 2012, 07:21 PM
euro911   Looks interesting. :popcorn: I don't know mu...   Aug 17 2012, 08:11 PM
kevin311   I got the ITBs mocked up on an engine today. I fou...   Nov 25 2012, 02:32 PM
Sleepin   Wow! Amazing project! Are the Harley ada...   Nov 25 2012, 02:48 PM
ConeDodger   I'm not sure how well this will work. I have t...   Nov 25 2012, 03:42 PM
Dave_Darling   If so, you had about 1.75" of throttle plate...   Nov 25 2012, 06:50 PM
DBCooper   If so, you had about 1.75" of throttle plat...   Apr 10 2013, 11:15 AM
ConeDodger   To answer your questions, yes, the stock pump on m...   Nov 25 2012, 03:48 PM
kevin311   I had similar thoughts about the throttles when I ...   Nov 25 2012, 04:47 PM
ConeDodger   I thought of that too. Carbs cover their sins in m...   Nov 25 2012, 04:59 PM
Dr Evil   Dont forget to use a phenolic spacer to soak up th...   Nov 25 2012, 06:25 PM
euro911   Dont forget to use a phenolic spacer to soak up th...   Nov 25 2012, 06:42 PM
wndsrfr   Super cool looking setup but I'm concerned wit...   Nov 25 2012, 06:32 PM
aircooledtechguy   Super cool looking setup but I'm concerned wi...   Nov 25 2012, 10:22 PM
FourBlades   Go go go! Love how cheap the tbs are... A gr...   Nov 25 2012, 06:42 PM
rdauenhauer   I had similar thoughts about the throttles when I...   Nov 25 2012, 07:21 PM
aircooledtechguy   I don't think you'll need to be too worrie...   Nov 25 2012, 08:28 PM
kevin311   So the project took a back shelf for a while becau...   Apr 10 2013, 10:25 AM
Mark Henry   Very cool, I'm about to do the same thing on m...   Apr 10 2013, 11:07 AM
monkeyboy   [quote name='Dave_Darling' post='1773574' date='N...   Apr 10 2013, 02:09 PM
rick 918-S   Just purchased a set of these VFR ITB's off eb...   Apr 10 2013, 07:39 PM
ThePaintedMan   Kevin, Three things. 1 - I'm glad that it...   Apr 10 2013, 09:34 PM
DBCooper   Those guys wad up bikes pretty frequently, so thos...   Apr 10 2013, 10:45 PM
ottox914   That is going to be amazing when done. Keep the u...   Apr 13 2013, 07:24 AM
kevin311   Thanks everyone! :beer2: Just a quick update...   May 12 2013, 09:57 AM
moparrob   Thanks everyone! :beer2: Just a quick updat...   May 12 2013, 01:13 PM
Dr Evil   Re-following this :D :popcorn:   May 12 2013, 05:58 PM
kevin311   Just a quick update for those interested. I finis...   Jul 14 2013, 03:47 PM
billh1963   Really looking forward to seeing how this works ou...   Jul 14 2013, 04:37 PM
aircooledtechguy   Looking good. . . :popcorn:   Jul 14 2013, 07:47 PM
rick 918-S   Excuse my ignorance I'm old so I do not know t...   Jul 14 2013, 10:03 PM
aircooledtechguy   Excuse my ignorance I'm old so I do not know ...   Jul 14 2013, 10:56 PM
Dave_Darling   Intake Air Temp sensor. Dunno why it's out th...   Jul 14 2013, 10:58 PM
kevin311   Yea I couldn't find a spot underneath that wou...   Jul 15 2013, 05:45 AM
craigrobbo   I came here from another forum with a similar buil...   Nov 20 2013, 04:05 AM
Mark Henry   I have a similar thread somewhere, I need to updat...   Nov 20 2013, 07:07 AM
craigrobbo   I have a similar thread somewhere, I need to upda...   Nov 20 2013, 03:45 PM
Mark Henry   [quote name='Mark Henry' post='1959555' date='Nov...   Nov 21 2013, 07:47 PM
kevin311   No updates lately. This project has been shelved f...   Nov 20 2013, 06:15 PM
2mAn   Bummed you didnt get a chance to finish, this is e...   Nov 21 2013, 04:44 PM
914_teener   I was interested in these working at all. Fun proj...   Nov 21 2013, 05:09 PM
rick 918-S   Any up dates?   Feb 3 2014, 04:30 PM
ClayPerrine   This is a cool project, but I think that you are g...   Feb 3 2014, 05:11 PM
Mark Henry   This is a cool project, but I think that you are ...   Feb 3 2014, 08:31 PM
r_towle   This is a cool project, but I think that you are...   Feb 3 2014, 08:35 PM
- Lo-Fi Version Time is now: 20th April 2025 - 07:35 PM
