FS: 1973 and a few 1972 914 parts***ALL SOLD**** |
rettigdw914 |
Aug 18 2012, 03:28 PM
Newbie Group: Members Posts: 16 Joined: 17-September 04 From: Greenwood, IN Member No.: 2,774 |
Here they are: Parts all 1973 914 unless otherwise specified Cost PIC 1 Porsche Haynes Manual $10.00 How to rebuild you Volkswagon $10.00 Porsche Factory Service manual (CDROM electronically searchable) $20.00 [s]Pedal assembly with brake switch $10.00 PIC 2 1972 ECU (works) $50.00 1972 Fuel injection wire harness off of a working car $10.00 Porsche Bra $20.00 PIC 4, 5 Used side shift tranny (PO said it worked OK. I used the 1st gear dog teeth to repair my car. it is missing a drain plug , the 1st gear synchro and dog teeth. Also the rear cover has a crached piece about 2" long which could be repaired. Good parts tranny for remaining gears. $100.00 PIC 6 Bilstein jack $25.00 Door Handle covers, targa holder clip from trunk, and shift linkage bushings $15.00 PIC7 1972 oil bath air filter housing $10.00 Valve cover gaskets $10.00 air filter housing bracket with 2 wingnuts $10.00 winshield washer tank $10.00 working throttle body (off of running car) $20.00 intake plenum with cold start and temp sensor (off of running car) $70.00 Auxillary air regulator (works) $40.00 Bosch Fuel Pressure regulator (unknown) $10.00 Fuel line manifolds (2) $5.00 Bosch Fuel Pump (spins with 12v connected) $40.00 new distributor condenser $5.00 intake manifold left and right $20.00 fuel tank rubber mounts $10.00 Buy all the parts together for $450.00 plus shipping and I will throw in the parts in PIC8 PIC8 Spark plug wires - worked OK on car "Spare - partially working parts: ECU - broken does not work brake caliper - frozen fog lamp - bulb out 2 - MPS - for parts only 4 - injectors - 2 click on and off, the others frozen[/s] " Thanks Don Attached image(s) |
rettigdw914 |
Aug 19 2012, 10:13 AM
tow hook and basket weave material are sold as well.
Lo-Fi Version | Time is now: 25th September 2024 - 10:57 PM |
