Oil change issues |
Oil change issues |
Natd |
Aug 22 2012, 05:31 PM
Newbie Group: Members Posts: 8 Joined: 22-August 12 From: San Diego Member No.: 14,838 Region Association: None |
I changed the oil on my 1972 914. When I start up the motor, oil starts leaking through by the top of the crank case. There is no oil leaking from the strainer. When I try and tighten the bolt it doesn't tighten at all. Is this a bad sign? Any ideas? What is that bolt for?
SLITS |
Aug 22 2012, 05:34 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Where on the case of the motor ... front, rear, right or left side? Leaking on the case seam?
And if you are overtightening the strainer bolt you will create one hell of a problem as in a broken case. |
Natd |
Aug 22 2012, 05:44 PM
Where on the case of the motor ... front, rear, right or left side? Leaking on the case seam? And if you are overtightening the strainer bolt you will create one hell of a problem as in a broken case. It's leaking out of a bolt on the passengers side. The 13mm one. |
Lo-Fi Version | Time is now: 31st October 2024 - 07:30 PM |
