Doug's A/C System, R&D/Build Thread |
dlee6204 |
Aug 22 2012, 08:05 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I thought I would document my A/C adventure in the hopes that it would be a good reference for anyone else considering A/C. I’ll first touch base on the stock system and on custom options and then start building my own system to start testing on. I’ve working on a few systems before but I'm sure there is someone that knows more than me so don't be shy sharing or adding anything. (IMG:style_emoticons/default/smile.gif)
To begin things off here is one of the better overviews of an A/C system. Follow the link and you can see a breakdown of the whole system. http://www.movacs.com/How%20it%20works/index.html Anytime I refer to the stock system I will be referring to the dealer installed VPC system mostly because the only A/C cars I had came with this system and I have plenty of parts around. I also borrowed some photos off this site so if I used any of yours... Thanks. (IMG:style_emoticons/default/smile.gif) Compressor: The compressor that came on dealer installed A/C systems was a York Piston style compressor that had a capacity of 6 cubic inches/Rev. From what I could find it used about 7-10 horsepower from the engine. You can still use this compressor however there are better, more efficient options out there. When choosing a new compressor it is a good idea to find one with a similar capacity. In this case going bigger does not mean better. An A/C system works as a whole unit and if you dramatically change one aspect of it, you will likely see negatives effects elsewhere. Choosing a compressor that’s too big will overwork the system, yielding no little to no benefit, and create a not-as-efficient system. During my search I looked mostly at Sanden style compressors so that's what I'll be referring to in my build. Using a modern compressor like the Sanden will only use about 3-4 hp from the engine. I have heard quite a few people use the Sanden 508 compressor with good results. It has an approximate displacement of 8 cubic inches/rev, which IMO is slightly more than I'd like to make a jump to. I'm not saying it wouldn't work, it obviously works, however I think I will get slightly better results and pressures using the Sanden 507 (approx. 7 cubic inches/rev). The SD507 is also slightly smaller in size than the 508. Here is a picture of the York Compressor A side by side with the SD507 And here is a SD508 |
dlee6204 |
Aug 23 2012, 02:57 PM
In a couple of days I can hopefully provide some photos of my AC install (LS1 conversion) that may be helpful to the -4 & -6 guys as well. I used an under dash evaporator (Hot Rod Air) that looks somewhat similar to the original dealer installed system (from memory of my '73, but that was more than 30 years ago). I opted to use reduced-diameter barrier hose which, as the name implies, the diameter (outside) is smaller than standard barrier hose. The smaller hose makes routing easier, and you don't have to punch such large holes. The fittings are more difficult to find, but Doc's Blocks (Stark Mfg) makes a whole array of there fittings; they recently stopped selling direct, so you'll have to contact them for a dealer. If you go with the reduced barrier hose, make sure your local AC shop has the correct crimping dies (most do not). Luckily, my local NAPA did have the correct ones, and did a great job. Andys Interesting. Please keep us updated. Do you have any specs on the hoses? As in, what the OD is? The size of regular hose is as follows: #6 ID: 5/16", OD: 3/4" #8 ID: 13/32", OD: 29/32" #10 ID: 1/2", OD: 1" |
Lo-Fi Version | Time is now: 28th December 2024 - 07:20 AM |
