> Creamsicle Refurb - Extreme Budget Makeover, Upgraded suspension, cleaned up engine, and more.
poorsche914
post Aug 23 2012, 05:52 PM
T4 Supercharged
Since purchasing my LE in the spring of 2010, I have slowly restored/replaced/upgraded items as time and money allowed. Yesterday, I drove 600+ miles to central Illinois to visit my cousin for a few days of marathon wrenching and reconditioning. I arrived around 5:30 local time and after going over "the plan", started cleaning and blasting some miscellaneous parts.
Today my cousin has redone the starter, rear shocks, and springs. We also dropped the drivetrain and I stripped the FI system and engine tin. Had major leaks from the push rod tube seals so have cleaned the engine of oil & dirt. Will be dropping the front suspension for reconditioning along with turbo tie rods and 21mm torsion bars. Also planned is some rust cleanup in the cockpit area along with a bdstone reconditioned pedal cluster (thanks, Bruce. Package arrived today!) and a battery tray installed and some engine bay cleanup.
QUESTION #1: Look at the picture below. Notice the tubes on the right have a shorter distance where the seals go than do the tubes on the left. Which tubes should I use or does it even make a difference? The reason I ask is because 4-5 of the tubes were leaking at that end. Not sure if the seals were bad (were brand new when I installed them a few months ago.) or if the smaller area played a part by not letting the seal move and do its job (IMG:style_emoticons/default/confused24.gif)
QUESTION #2: I am installing a set of 140# Weltmeister springs and one end of them has a tighter coil. Does this end go up or down? Found a couple pics online but of course one had it up and one had it down (IMG:style_emoticons/default/dry.gif)
Thanks! More pics later.
TheCabinetmaker
post Aug 24 2012, 04:38 AM
I drive my car everyday
Steve, I don't think the pushed tubes should be an issue. More than likely the seals were of the non viton material. Be sure to lube them and install the tubes with a twisting motion. They cut easily.
poorsche914
post Aug 24 2012, 06:35 AM
T4 Supercharged
Thanks, Curt. I was thinking it was probably the seals rather than the tubes. Will replace with correct viton type.
poorsche914   Creamsicle Refurb - Extreme Budget Makeover   Aug 23 2012, 05:52 PM
dlee6204   I can't help with your questions but good luck...   Aug 23 2012, 06:51 PM
hot_shoe914   You do know the damn thing will never get you back...   Aug 23 2012, 07:30 PM
poorsche914   Yeah, I know, Shoe... tempting fate here. Thanks,...   Aug 23 2012, 09:19 PM
poorsche914   Pictures! Engine bay :barf: Engine out...   Aug 24 2012, 06:44 AM
poorsche914   Pedal cluster from bdstone Starter Air box :...   Aug 24 2012, 06:48 AM
poorsche914   You do know the damn thing will never get you back...   Aug 30 2012, 10:19 PM
poorsche914   To bring everyone up to date... Day 4: remaining ...   Aug 30 2012, 10:45 PM
The Cabinetmaker   Steve, I don't think the pushed tubes should b...   Aug 24 2012, 04:38 AM
poorsche914   Thanks, Curt. I was thinking it was probably the s...   Aug 24 2012, 06:35 AM
rnellums   Looking good! As far as the springs go, It sh...   Aug 24 2012, 07:41 AM
poorsche914   Thanks, Ross. We ended up putting the tighter coil...   Aug 24 2012, 11:24 AM
87m491   Here is a shot of one of his projects. Guess the...   Aug 24 2012, 01:41 PM
poorsche914   Sure looks Corvette to me... You are correct... 19...   Aug 24 2012, 02:11 PM
rnellums   Independent rear suspension?   Aug 24 2012, 11:43 AM
rex66m   Steve - Glad to hear that you are continuing to ...   Aug 24 2012, 09:57 PM
poorsche914   Day 2: rear shocks and springs reconditioned and r...   Aug 24 2012, 10:24 PM
poorsche914   DAY 3: Rear shocks with 140# springs Front susp...   Aug 25 2012, 10:45 PM
BajaXJ92   Subscribed. :D   Aug 25 2012, 10:48 PM
MrHyde   What you need is this :)   Aug 26 2012, 03:16 PM
poorsche914   :agree: All in good time :) It's going to be ...   Aug 26 2012, 05:38 PM
matt5596   Very motivating :cheer: I may actually get some...   Aug 31 2012, 09:12 AM
- Lo-Fi Version Time is now: 3rd April 2025 - 08:35 PM
