Tuna Can Installation, Need Info ... |
euro911 |
Aug 28 2012, 01:52 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,855 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I recently picked up a 'previously owned' steel tuna can, but all I got was the can and bolt. Does anyone have a copy of the installation instructions or info on extending the pick-up tube, gaskets or seals needed ... and can tell me if the strainer relocates down to the bottom of the 'can'? (IMG:style_emoticons/default/confused24.gif)
Dave_Darling |
Aug 28 2012, 11:43 AM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The pickup tube extension is, from what I can tell, machined out of a billet piece of rod. There is a groove on the inside up at one end for the O-ring, and the other end is closed except for the wide slots cut in an X shape on the end. There might be a hole on the end larger than were the slots meet, but it might just be the slots. Regardless, the retaining nut goes through where the slots meet.
Not an easy part to make, and if it does not seal you're going to be sucking air most of the time. Not so good. You only got half the kit, you need the other half as well. --DD |
Lo-Fi Version | Time is now: 27th September 2024 - 10:19 AM |
