metalmorphosis |
Member ![]() ![]() Group: Members Posts: 90 Joined: 31-July 12 From: winston-salem nc Member No.: 14,743 Region Association: South East States ![]() |
I need some help remembering how exactly the fuel lines go. The car is a 73 1.7 w stock fuel injection and pump in stock location. The pump has a S, D, and R on it and I'm pretty sure thats obviously supply, divert, and return. So my 1st question is where does the D or divert line goto? The 2nd question is that it looks like once the supply line gets to the engine it 1st goes across to the driver side to the regulator then to the fuel rails and back down to the return side of the pump is this right? Thanks in advance for any advice and/or pics.
Gabe Attached thumbnail(s) ![]() ![]() |
timothy_nd28 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest ![]() ![]() |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,208 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
![]() My 73 fuel line routes through the CSV on the 1.7 on top of the motor above the tin. On advice......ditch those clamps that you have and get some new fuel line before you put that in the car. Not sure why your test is not working other than the pump might be cavitating or the line near the tank is kinked or tank plugged. Good luck. |
Black22 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest ![]() |
On advice......ditch those clamps that you have and get some new fuel line before you put that in the Good luck. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 10:52 PM |
