Woody |
Sandbox Rabblerouser and head toilet scrubber ![]() ![]() ![]() ![]() Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region ![]() |
Well its time to upgrade the shocks on my car. It is primarily used for AX with a trackday thrown in. Currently the car has T struts, 21mm torsion bars, 19mm sway bar, and monoball strut mounts and 180 pound springs in the back. All the bushings have been replaced with delrin. I would like to lower the car a little bit more but am limited with the current T struts. I was intending to go with Koni or Bilstein inserts and shocks with a coil over kit on the rear but then I happened across these which are still in the budget but barely.
http://www.tarett.com/items/914-products/9...strt-detail.htm http://www.tarett.com/items/914-products/9...rshk-detail.htm I do have a set of calipers that I should be able to use since mine currently have the 3" spacing. Will the T hubs work on the RSR spindles? Any thoughts on this? Should I just keep it simple and go with the Konis? |
Woody |
Got all my new goodies put on. Went with the Bilstein HDs, Rebel Racing rear coil over kit with 250lb springs, turbo tie rods with RSR bump steer kit, a Rennshifter, and a Momo Prototipo steering wheel. Balanced and aligned it this morning. Have an AX next Sunday and another the following Saturday. I can't wait. I think it will probably be time to ditch the Weltmeister 19mm swaybar and go with something more substantial and better quality. Here's the corner balance, with me in the car.
Lo-Fi Version | Time is now: 26th June 2024 - 02:25 AM |
