OT: 944 Calipers, I know some of you guys have 944's... |
Eric_Shea |
Sep 18 2012, 07:54 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Just wanted to show off our newest build... 944 single piston, floating steel calipers:
(IMG:http://www.914world.com/bbs2/uploads_offsite/sphotos-b.xx.fbcdn.net-1110-1348019689.1.jpg) This is our first couple of sets. We finished these for Henry at Intermeccanica. Really happy with the way they turned out. I must say, I like the ATE's much better than the Girling version found on various VW Buses etc. You can see the build process here: https://www.facebook.com/media/set/?set=a.1...mp;l=88d2516f44 |
Eric_Shea |
Sep 19 2012, 07:33 AM
QUOTE How about 928s4 calipers Eric, do you rebuild those? We have a full set here we're experimenting with. The problem with the later Brembo's is... Brembo. They have made the kits unbearable. Each bore seal is $25.00. Each dust boot/wiper seal is $32.00. Now x8 ($456) or x16 ($962) and you've just covered the "rubber" bits for your restoration. To refinish them properly requires fully stripping them, de-anodizing them, re-anodizing them in black, assembling them, clear coating in high temp clear and then re-machining the PORSCHE logo. There's another $400 per pair to get them like factory new. Who's ready to pony up $849.00 per pair for these dime-a-dozen calipers? This is why I currently call them "throw-a-way" calipers. The spring plates in the pad cavity are also a problem. Almost all of the fasteners need to be machined out. Small fastener in steel into an aluminum body. Again, we're experimenting with some low cost finish alternatives. It's admittedly a back burner project. |
Lo-Fi Version | Time is now: 27th December 2024 - 01:56 AM |
