mrholland2 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 753 Joined: 7-September 11 From: Santa Maria,CA Member No.: 13,531 Region Association: Central California ![]() |
YAY: I can use headlights without blowing fuses. .. and the horn also now goes "Merrrrp merrrrp" (kind of like a European See-And-Say)
HOWEVER, When the car is OFF the key is OFF and I (accidentally) engage the RIGHT turn signal, the RIGHT park and tail lights come on. . and (I think) the same with the LEFT. Also, the headlights would not work with the wires hooked to the proper locations (according to a thread on here). I'm wondering if my switch is "ker-flooey" and needs replacement? Or do I have the only 914 that was worked over by Lucas Electrical? Sean |
jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,334 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
I believe all 11 pins are wired the same.
mrholland2 |
jim_hoyland |
I believe all 11 pins are wired the same. The photo vanished from your post!!!! Reposted..... (IMG:style_emoticons/default/smile.gif) I had a switch with all the wires still attached and went through all the circuits with a continuity tester. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:07 AM |
