914-6 setting timing, How do you get to it? |
bfrymire |
Sep 26 2012, 06:54 PM
Salsaholic Group: Members Posts: 590 Joined: 1-August 04 From: Sunnyvale, CA Member No.: 2,431 Region Association: Northern California |
This may seem stupid.. But, I went to check the timing, and I can't get to it. The timing marks are right up against the firewall. So, is there some trick to it? And, I hope you don't have to crawl under a running car to get to it...
-- brett |
ArtechnikA |
Sep 26 2012, 07:18 PM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
The timing marks are right up against the firewall. Ahh - no. There are TDC marks on the crankshaft pulley, but they are intended to be used when setting valve lash. The _timing_ marks, which include TDC and 35º BTDC, are on the _flywheel_ and are visible through a notch in the bellhousing. |
bfrymire |
Sep 26 2012, 07:23 PM
The timing marks are right up against the firewall. Ahh - no. There are TDC marks on the crankshaft pulley, but they are intended to be used when setting valve lash. The _timing_ marks, which include TDC and 35º BTDC, are on the _flywheel_ and are visible through a notch in the bellhousing. ahhh. (smacking my forehead). The picture in my book, showed the pulley. thanks! -- brett |
bfrymire |
Sep 26 2012, 07:25 PM
Which brings on another question... I have a 2.7l, with cis converted to megasquirt. The spec shows 5 atdc initial and 38 total. Is this what I should be using? --brett The timing marks are right up against the firewall. Ahh - no. There are TDC marks on the crankshaft pulley, but they are intended to be used when setting valve lash. The _timing_ marks, which include TDC and 35º BTDC, are on the _flywheel_ and are visible through a notch in the bellhousing. ahhh. (smacking my forehead). The picture in my book, showed the pulley. thanks! -- brett |
Lo-Fi Version | Time is now: 15th January 2025 - 05:35 AM |
